09-17-2014, 08:34 AM | #1 |
If you found this setup how would you run it
Found a Fenton exhaust manifold with intake,2 1904's and valve cover for a 215 6 cylinder.Plan is to use it but how should i run the exhaust?? thinking straight pipe,your ideas are welcome.
09-17-2014, 08:57 AM | #2 |
Re: If you found this setup how would you run it
