09-02-2014, 06:53 AM | #1 |
53 front springs
I want to change the front suspension springs on my 53 club coupe. Haven't got a manual yet, wondered if someone could tell me the correct safe procedure for getting the front springs out
Thanks Ian |
09-02-2014, 08:17 AM | #2 |
Re: 53 front springs
Ian, Hopefully here is a copy of page from Manual.
Don |
09-02-2014, 01:24 PM | #3 |
Thanks for that
Is the stabiliser the sway bar/anti roll bar? |
09-02-2014, 04:37 PM | #4 |
The stabilizer or sway bar connects to bumper plate by the lower arm. Don
09-02-2014, 04:46 PM | #5 |
Will have a look under there tomorrow
Ian |
09-02-2014, 05:19 PM | #6 |
09-02-2014, 05:32 PM | #7 |
My intention is to fit some Aerostar springs. Just hope I can get the old ones out
Ian |
09-03-2014, 09:33 AM | #8 |
Those instructions worked great, quite easy to get em out, do have to be careful tho!!
Easy to get the shirt aerostars back in. Now for the rear Ian |
09-03-2014, 10:44 AM | #9 |
Seems like a lot of work to drill out the rivets, If you want to change the springs later that would make it very easy. You can buy new springs from Carpenter, for $200.
09-03-2014, 12:05 PM | #10 |
Once you change the height you will need an alignment.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
09-03-2014, 01:52 PM | #11 |
What are the alignment specs after lowering?
Ian |
09-03-2014, 05:48 PM | #12 | |
09-03-2014, 06:04 PM | #13 |
Yep I can confirm they will lower the car 2 1/2" (fitted them today) got mine from summit,think they were around $50. Bargain. Yet to drive mine tho, just looking at it in the driveway!!
Ian |
09-03-2014, 06:40 PM | #14 |
Did you have to change the shocks or will the stock one's work?
