Old 11-26-2013, 06:02 AM   #1
40ford
40ford's Avatar
Default 1940 Rear Tube Shocks:
What is the best and easy to install rear tube shock kit for a 1940 sedan?I was looking at the kit C & G has listed.Has anyone used this kit?I have one of the lever types leaking and I thought this would be a cheaper and better way to go!They say there is no welding involved????
40ford is offline   Reply With Quote
Old 11-26-2013, 08:45 AM   #2
skidmarks
skidmarks's Avatar
Default Re: 1940 Rear Tube Shocks:
Or buy one of the 1950's conversion kits.
skidmarks is offline   Reply With Quote
Old 11-26-2013, 09:21 AM   #3
19Fordy
19Fordy's Avatar
Here is one of those 1950's conversion kits installed in 1961. When you install it try to get the shock to be as vertical as possible since the more angle you have the less efficient the shock is. You have to make sure the shock 'clears" the exhaust pipe and gas tank. Do a search for helpful info. http://www.jalopyjournal.com/forum/s...d.php?t=507364
Old 11-26-2013, 10:44 AM   #4
skidmarks
skidmarks's Avatar
that shock is layed over to the point it almost useless.
or just get the lever action shock rebuilt. if its a nice car and not hacked up i would rebuilt the stock shocks
Old 11-26-2013, 11:11 AM   #5
blucar
blucar's Avatar
There are several very reliable re-builders of the lever type shocks across the U.S.. Converting to tube type shocks will in the long run be more expensive than having the original shocks rebuilt.. One the nice features about the original lever shocks is that they are adjustable, i.e. from firm to soft...
As a general rule, the original Ford lever shocks are double action, therefore they do a good job of limiting body roll, this can not be said of the tube shocks laying on an angle...
Bill.... 36 5 win cpe
Old 11-26-2013, 11:15 AM   #6
19Fordy
19Fordy's Avatar
Here's another viewpoint.
http://www.jalopyjournal.com/forum/s...d.php?t=520339
This is very helpful.
http://www.jalopyjournal.com/forum/s...d.php?t=594512
Old 11-26-2013, 01:15 PM   #7
woodiewagon46
Have you looked at the one's offered by Chassis Engineering, 319-643-2645, www.chassisengineeringinc.com? Bill Wzorek, 413-586-5324 rebuilds early Ford shocks.
woodiewagon46 is offline   Reply With Quote
Old 11-26-2013, 01:29 PM   #8
Kahuna
Kahuna's Avatar
Another option is to use MGB rear lever shocks
Kahuna is offline   Reply With Quote
Old 11-26-2013, 03:49 PM   #9
larrys40
In my opinion I would opt to keep the original lever action shocks. Older rebuild units can still be had on ebay or swap meets on occasion, or those rebuilt by M & S or apple hydralics.. or others. check the V8 times magazine from the Early Ford V8 club .
My '40 convert had the tubes and I went back to the lever action... and it rides and handles so much better. The key is having good ones on...
Good luck,
Larry S.
larrys40 is offline   Reply With Quote
Old 11-26-2013, 08:52 PM   #10
Jake H.
Jake H.'s Avatar
Not the best photo, but I just installed the rear tube shock/sway bar kit from Bob Drake in my '39 Tudor.
$200 and it was a bolt-in deal.
It works awesome. The car rides nice and corners so much better.
The only gripe I had with the kit was the nuts and bolts supplied were garbage. I threw them away and bought all grade 8 stuff from Ace Hardware.
Jake H. is offline   Reply With Quote
Old 11-27-2013, 12:21 AM   #11
40ford
40ford's Avatar
Jake,what was the part # on the kit you used?Is it for stock suspension and will it give the stock height?Is there any drilling or welding involved?
Old 11-27-2013, 12:38 AM   #12
Jake H.
Jake H.'s Avatar
I got the kit for a lowered 2-3" rear.
The part # for a stock height rear is BD-18000-K.
It required some grinding on the rear crossmember, for shock clearance.
Also, you need to drill out the rearmost crossmember rivets, and drill two additional holes in the frame, for the sway bar bushing mounts.
No welding needed, all bolt-in. But do use grade 8, instead, wherever possible...
It's a stout, 7/8" sway bar, and I am very impressed with its performance.
As you can see, in the photo, my big ol' 8.20/15" bias-plys rubbed on the inside, during cornering, before.
Now it's flat as a pancake, and rides really nice, too.
Old 11-27-2013, 01:10 AM   #13
Kahuna
Kahuna's Avatar
Jake
Does the $200 or so dollars include the shock kit?
Thanks
Jim
Old 11-27-2013, 07:16 AM   #14
jon laing
How does one know when stock shocks are not performing properly? Is there a test I can perform? Jon Laing
jon laing is offline   Reply With Quote
Old 11-27-2013, 10:31 AM   #15
TJ
TJ's Avatar
Jake, you need a few longer spring leafs in that rear spring. The bow in that spring, without some support will eventually break the spring. Use some longer leafs on the top of the main leaf and eliminate some short ones on the top of the spring..
Old 11-27-2013, 11:52 AM   #16
blucar
blucar's Avatar
I know several guys that have MG's, two of which have been converted to Ford V8 60 engines..
The MG guys use Ford lever action shocks on their cars.. The MG stuff is according to them junk... Early Ford V-8 brakes are also a common modification on MG's with a Hudson rear end..
Old 11-27-2013, 12:46 PM   #17
Jake H.
Jake H.'s Avatar
Thanks TJ.
I am pulling the whole rearend back out this holiday weekend.
I plan on adding some leaves, so I will definitely add the longer ones back.
I need to tear down the banjo (stripped driver's axle thread, arrrrgh), possibly throw some freeway gears in, and wire wheel/detail paint everything under there.
The $200 DOES include the tube shocks, mounts for top and bottom, and all swaybar assembly.
Old 11-27-2013, 09:24 PM   #18
TJ
TJ's Avatar
$200 sounds like a good deal on all that hardware.
Old 08-31-2020, 11:59 AM   #19
Lafe
CAN YOU GIVE ME THE BRAND NAME & PART # OF THE TUBE SHOCKS YOU ARE USING? MY 39 HAS THE SHOCK CONVERSION ALREADY ON IT BUT I NEED TO REPLACE THE SHOCKS AS THEY ARE BAD. GABRIEL DOES NOT HAVE THE SHOCK THAT WAS USED, PART # 778 FRONT & 603 REAR ANY LONGER. THANKS MIKE, La Center, WA
[email protected]
Lafe is offline   Reply With Quote
Old 09-01-2020, 09:34 AM   #20
forte
Will lever shocks perform well using radial tires?
forte is offline   Reply With Quote
