Old 09-17-2014, 08:34 AM   #1
lastyrshoebox
lastyrshoebox's Avatar
Default If you found this setup how would you run it
Found a Fenton exhaust manifold with intake,2 1904's and valve cover for a 215 6 cylinder.Plan is to use it but how should i run the exhaust?? thinking straight pipe,your ideas are welcome.
lastyrshoebox is offline   Reply With Quote
Old 09-17-2014, 08:57 AM   #2
Marv
Marv's Avatar
Default Re: If you found this setup how would you run it
2" straight pipes.
Marv is offline   Reply With Quote
