Old 09-07-2020, 02:56 PM   #1
1930artdeco
1930artdeco's Avatar
Default Recycle or sell?
Hi all,
I have a spare torque tube that I need to do something with. Is it worth selling or recycling?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 09-07-2020, 03:29 PM   #2
Dick So. Cal.
Default Re: Recycle or sell?
Check with the Mitchell folks to see if they could use it for their overdrive.
Dick
Dick So. Cal. is offline   Reply With Quote
Old 09-07-2020, 03:32 PM   #3
1930artdeco
That is an idea.
Mike
1957 Country Sedan
Old 09-08-2020, 09:11 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
Some have been used for collectors on home made exhaust headers .
Old 09-08-2020, 09:20 PM   #5
SteveB31
SteveB31's Avatar
I have scrapped a couple hundred of them in the last couple years. They never break, so nobody needs them.
SteveB31 is offline   Reply With Quote
Old 09-08-2020, 09:39 PM   #6
1930-Pickup
I just parted out a rear axle, in large part due to a damaged torque tube. Sort of.
Root cause of the failure was at the pinion gear double tapered bearing race, which was slip-fit loose in the banjo housing. The spinning race ground its way forward about 1/4" into the back end of the torque tube.
So you could say "why not just replace the torque tube, and the banjo housing, and the bearing race"? Because as the bearing race was making its way forward it turned a good chunk of the torque tube into powder, which got into everything, and messed up all those other parts.
So Steve, when you say "they never break", I'm sure you mean "I've never seen a broken one".
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 09-08-2020, 09:41 PM   #7
Tim Ayers
A torque tube can, but they are really heavy for that. Ideally, a '35/'36 driveshaft is used for this.
Old 09-08-2020, 10:14 PM   #8
31a
I hauled some to swap meets for years unable to sell at all!!
31a is offline   Reply With Quote
Old 09-08-2020, 10:18 PM   #9
Jack Shaft
^^^ the same guys who scream 'save everything' walked right by^^^
Old 09-08-2020, 10:23 PM   #10
redmodelt
redmodelt's Avatar
I was going to post something like that!
