07-06-2020, 02:34 PM | #1 |
ground fault on upper distributor plate
Today I found a ground fault on the upper distributor plate. The short circuit is at the bolt, which allows the rotation of the points. Here the insulation to the plate is not ok.
I see the construction of the plate at this point as problematic. Did somebody have this fault too? Greetings Gero |
