Old 06-27-2020, 03:32 PM   #1
fred93
fred93's Avatar
Default 29 Tudor crank pulley question
I was reinstalling the generator that I just rebuilt and I noticed that the two piece crank pulley had some play between the pulley piece and the separate rear piece.
It is not a lot of play but I'm thinking that there should not be ANY play at all. The pulley bolt is tight so I am wondering why there is play??
Also--can I tighten that bolt with a socket and extension through the crank hole in the radiator shell--what size socket???
Any thoughts?
Why is there never enough time to do it right, but always enough time to do it over!!!
fred93 is offline   Reply With Quote
Old 06-27-2020, 04:02 PM   #2
Bob C
Default Re: 29 Tudor crank pulley question
It is possible the nut is bottomed out on the crank snout, you may
need to add a washer. The ID of the washer need to be a little bigger than the OD of the snout.
Old 06-27-2020, 04:18 PM   #3
kenparker
kenparker's Avatar
There should be NO rotational movement between the two pieces of the two piece crank pulley. It will get worser and mo worser.
kenparker is offline   Reply With Quote
Old 06-27-2020, 06:48 PM   #4
Synchro909
Synchro909's Avatar
Wink Re: 29 Tudor crank pulley question
It won't get any worser once it fails and I fear failure is not far away if it the thread that holds the pulley to the hub is loose or damaged.
Old 06-27-2020, 08:17 PM   #5
Big hammer
The nut can be tighten or loosened with a socket and extension, put the socket over the nut and then an extension through the hole where the hand crank goes. Socket size is 1 1/16 I think maybe 1 1/8 ? I changed my pulley a year ago memory has faded
get a bigger hammer tap done
Old 06-28-2020, 08:47 AM   #6
fred93
fred93's Avatar
Thanks for your reply.
I guess the repro devil strikes again! (repro parts almost fit!!)
The socket size is 1-3/8" --I found it in Snyder's catalog. See photo.
Old 06-28-2020, 08:50 AM   #7
fred93
fred93's Avatar
I was thinking the same thing (a washer) but I figured that I better ask before I actually do it.
BTW I do have the special wrench for that bolt.
Old 06-28-2020, 09:07 AM   #8
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
Fred93, I would check the lugs on the pulley and collar for damage caused by the movement. I 'm speaking from experience and I went back to a one piece pulley. A little more work but peace of mind. Good Luck, I miss my 28 tudor currently drive a 31 coupe.
Dan
dansluck is online now   Reply With Quote
Old 06-28-2020, 10:03 AM   #9
katy
katy's Avatar
They're not all 1-3/8", the one on my '31 CCPU is 1-1/4" and I've heard of 1-5/16" ones.
Old 06-28-2020, 10:05 AM   #10
fred93
fred93's Avatar
Dan
Thanks for the reply.
Fortunately there is only about three hours of run time on the engine and pulley assembly. The car has not been driven at all at this point so I don't think that I will have any problems like you mentioned.
Good thought though for the future.
Old 06-28-2020, 12:44 PM   #11
fred93
fred93's Avatar
I removed the crank pulley bolt and looked at the situation. The actual crankshaft only sticks out a small amount beyond the pulley.
A washer would be difficult to place in that area and keep it from getting stuck between the bolt and the crankshaft. It looks like I would need to have someone braze material to the front of the pulley and then machine it down to match the crankshaft. Or have someone make a washer and tack weld it to the pulley so it will stay in place while tightening the bolt.
Anyone have any other ideas???
Old 06-29-2020, 09:08 AM   #12
katy
katy's Avatar
How about a small washer to fit behind the pulley?
Old 06-29-2020, 03:23 PM   #13
fred93
fred93's Avatar
That was a thought that passed through my brain. But what I ended up doing was to make a washer (brass sheet .016" thick) that had the ID a tad larger than the crankshaft and a OD the size of the pulley machined area. See photos.
Then I super glued the washer to the crankshaft pulley just so it would stay in place while I tightened the crankshaft bolt. It worked great! No more play!
Old 06-29-2020, 09:43 PM   #14
fred93
fred93's Avatar
Thanks--that is normal for Henry! LOL
