07-21-2021, 11:50 PM | #1 |
C:\Users\Owner\Pictures\2021-07-13
expermnt
07-22-2021, 12:03 AM | #2 |
Re: C:\Users\Owner\Pictures\2021-07-13
Negative. I believe if you follow instructions in post #6 in this thread you'll be successful.
https://www.fordbarn.com/forum/showthread.php?t=301357 |
07-23-2021, 06:09 AM | #3 | |
07-23-2021, 06:40 AM | #4 |
07-23-2021, 10:22 AM | #5 |
When I finally figured it out, I set the picture resolution low enough on the camera I use to take shots for the forum so that the pictures always fit. They were still fine for general viewing and would upload directly. The problem is that most cameras (phones, iPads, etc.) are too advanced for use on the forum. Their pictures are just too "good". Luckily, just about everything can be reset for the lower resolution and will produce pictures that will upload. Those of us who (either intentionally or through luck) have our devices set to the lower resolution will never see a problem, while a "Newbie" with the latest iPhone will have tons of problems. |
