Old 07-21-2021, 11:50 PM   #1
highbeams
highbeams's Avatar
Default C:\Users\Owner\Pictures\2021-07-13
expermnt
highbeams is offline   Reply With Quote
Old 07-22-2021, 12:03 AM   #2
tomcarman
tomcarman's Avatar
Default Re: C:\Users\Owner\Pictures\2021-07-13
Originally Posted by highbeams View Post
expermnt
Negative. I believe if you follow instructions in post #6 in this thread you'll be successful.
https://www.fordbarn.com/forum/showthread.php?t=301357
tomcarman is offline   Reply With Quote
Old 07-23-2021, 06:09 AM   #3
highbeams
highbeams's Avatar
hmmmm. Does Post number 6 have a name? Thank you
Old 07-23-2021, 06:40 AM   #4
Bruce of MN
Bruce of MN's Avatar
https://www.fordbarn.com/forum/showp...72&postcount=6
Bruce of MN is online now   Reply With Quote
Old 07-23-2021, 10:22 AM   #5
tubman
tubman's Avatar
"JSeery"'s post #6 in the aforementioned thread is fine, and will work if the picture is "small" enough (pixel-wise). Where I had my problems when I first tried this was that I would get an error message when the system finally tried to upload the picture. The upload process would fail because the system would consider the picture too large. I don't remember the exact error message, but I seem to remember that it was misleading, and it took me a while to figure out what was actually going wrong.
When I finally figured it out, I set the picture resolution low enough on the camera I use to take shots for the forum so that the pictures always fit. They were still fine for general viewing and would upload directly. The problem is that most cameras (phones, iPads, etc.) are too advanced for use on the forum. Their pictures are just too "good". Luckily, just about everything can be reset for the lower resolution and will produce pictures that will upload. Those of us who (either intentionally or through luck) have our devices set to the lower resolution will never see a problem, while a "Newbie" with the latest iPhone will have tons of problems.
