09-07-2012, 01:12 AM | #1 |
Ford Y Block Distributor Identification
y blocker's
the distributor is loose. i hold it up and look where for the stamped in number? anybody know about these later y block distributor's sharing parts with the Windsor engines? points, cap and rotor. have a nice day!
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote |
09-07-2012, 07:31 PM | #2 | |
Re: Ford Y Block Distributor Identification
All the innards of a mid to late 60's Windsor distributor will interchange with the 58 on dissy. The only real difference is the drive shaft is longer and the gear is different.
Regards
Rick West Australia 1958 Ford Mainline Utility, 1955 Ford Tudor Sedan Quote:
09-08-2012, 01:55 PM | #3 |
rick
looked at caps on NAPA. i was ready to get into this 'Ford' thing with a Ford Blue cap. they only have that bakelite brown. oh well! regards
09-20-2012, 12:30 AM | #4 |
y blockers
here's what's stamped on distributor housing. 12127 in the little rectangle there's a capital 'M' to the right. then FoMoCo cast in. there might be a faint '650' to the left. anybody know what distributor this is supposed to be? have a nice day!
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote Last edited by all american boy; 09-20-2012 at 12:48 PM. |
09-20-2012, 08:06 AM | #5 |
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
12127 is the base part number for all distributors. The M is design info. You need what's in front of the -12127- to determine year and application.
09-20-2012, 09:44 PM | #6 |
09-21-2012, 12:47 AM | #7 | |
Rad1138 you are not totally correct. Cleveland engine distributors are a whole different beast using completely different components, certainly the ones here in Oz anyway.
Regards
09-21-2012, 01:48 AM | #8 |
y blockers
my distributor matches up with later Y block description on Timmy's Y Block page. i'm not going to clean distributor anymore until it's time to go through it and put it back on. it did run the engine so it's a y block distributor. have a nice day!
09-28-2012, 04:47 AM | #9 |
There were four cap styles as I remember-
B7A 12106-A was the 57/ original black cap B7AZ 12106-A was the 57/ Transistorized Ignition brown Bakelite cap D5AZ 12106-A (75/ ) was the first DURASPARK II cap (small) and was blue E7TZ 12106-A (77/ ) DURASPARK II cap large (used w/ adapter) grey in color (early blue) Basically, all parts are interchangeable from 58 to early 74. The 57 Y had a slightly different point style than the 58/ . Exactly what are you trying to do?
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
09-28-2012, 04:50 AM | #10 |
Here, the distributor housings are the same for the 335 (351C) and 385 (429-460) Series engines.
09-28-2012, 02:01 PM | #11 |
kult ulz
you caught me! i'm looking for the 'most bang for the buck' way to upgrade the ignition plus keep it all Ford. Duraspark II fits the bill! good old wikipedia: 'The Duraspark II ignition system is a common upgrade for older Ford cars equipped with a points type ignition. In most cases the distributor will interchange with the older style points distributor. The system is similar to some aftermarket systems and the control module may be easily swapped.' thanks kultulz! have a nice day!
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote Last edited by all american boy; 09-28-2012 at 04:37 PM. |
10-13-2012, 03:24 PM | #12 |
y blockers
took another look at my distributor. it does have a triangular body! this is from Mummert's technical page. 'Late and service replacement distributors use the 289 style triangular body with o-ring seal.' i was looking at stamped numbers and letters. i'll give it a little scrubbing and see. have a nice day!
10-16-2012, 07:37 PM | #13 |
y blockers
scrubbed off area where 4 letter and number code is. it looks to me like '08AF'. here's Mummert's distributor chart. http://www.ford-y-block.com/distributors.htm plan is to check centrifugal advance weights to see if they are late 'triangle' type and call it good. gave me eyestrain looking at that part number! have a nice day!
10-16-2012, 10:13 PM | #14 |
There's no "0" in the first spot of a Ford part number. It's either B,C,D,E or F. They signify respectively the decades of the 50's, 60's, 70's, 80's and 90's. Your "0" is probably a "C".
10-19-2012, 04:36 PM | #15 |
The Duraspark II upper rotor shaft should fit on the "C8" (Y-block service replacement) version - like this.... There are several versions which set of advance slots do you have?
10-19-2012, 06:55 PM | #16 |
Greenbird, is there a "special" tool for getting the clip off to remove the upper rotor shaft. Hard to get in there. Last time I had mine apart I thought I would never get that clip back on (not to mention my eyes are crap).
The Master Cylinder Enjoying life at the beach in SoCal... |
10-21-2012, 10:51 PM | #17 |
It's some combination of two small screwdrivers (to spread the clip on the way out) - and like playing the banjo, holding your mouth right.
Going back in is similar...... |
10-22-2012, 07:58 AM | #18 | |
Grab one end of the clip with needle nose plyers , hold really tight and pull and twist at the same time. Works like a champ , we have removed hundreds of these . Straighten clip ( assuming you bent it coming out) and push back in with small screwdriver . Note : Be carefull what you lube this shaft and cam inside with , thick grease will slow the advance down , We use a thin spray lube or light oil..... |
10-22-2012, 08:02 AM | #19 | |
Note that the spring retainers (outside) are bendable. No need to chang springs just bend tabs in and out to get a proper advance curve. Note one spring (not shown) is heavy and the other is light . Thats low and high speed advance . Spring tension may be adjusted thru a hole in breaker plate to modify advance rate. |
10-23-2012, 12:25 AM | #20 |
Bubba, good info. Thanks. Be careful when bending the tabs, I got a "rebuilt" distributor from NAPA that had the tabs bent at some time in the past. But they were bent in a fashion that prevented one of the weight to move freely.
