02-09-2012, 12:20 PM | #21 | |
Re: 1960 f100 with 292 yblock which auto trans to use?
02-09-2012, 02:53 PM | #22 |
56 custom
good part is you you just did the pulling engine & tran routine so putting it back should go smoothly. as far as original trans leaking and shifting rough i'd say it ought to to be good for about a year of normal use. that unknown tranny if you put it in and it didn't work at all that would be no good. Have A Nice Day!
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote |
02-09-2012, 03:11 PM | #23 |
Well I guess I will be using the old trans? I just dont know what all these lines hook up to. Im going to have to try and post some pics and possibly tranny numbers?
02-09-2012, 05:21 PM | #24 |
You trans cooler should look something similar to this. Also notice screen on back of bell that you mentioned.
02-09-2012, 05:27 PM | #25 |
Yes that looks very similar to mine! Is it possible that cruise o matics had the same set up?
02-09-2012, 08:51 PM | #26 | |
As I mentioned in my e-mail I would go with the original trans, converter, and flex plate on the new engine. See if you can get some clear pictures so we can see the "hard lines you mentioned that were bolted to the engine? And to determine where to connect the coolant inlet and outlet. |
02-09-2012, 09:01 PM | #27 | |
02-10-2012, 10:23 AM | #28 |
Just a thought... I think you mentioned a hard line from the BACK of the trans case to the engine. That is probably the line from the vacuum modulator to a vacuum source on the engine (such as carb base, intake manifold, etc.)
02-10-2012, 10:42 AM | #29 |
Thats what I thought too. But it isnt hooked up to anything.
02-10-2012, 10:56 AM | #30 |
forder's
my cruisomatic has 3 fittings on passenger side. 2 of them, one above the other up front, sticking straight out. and one at lower rear edge that angles up. i poked around under grunge and i don't think their is tin oval tag riveted to oval place on trans. there might be little tag on pan bolt. certainly could be there under grunge! i'll post some pic's in a couple weeks. nice and clean, all four sides. Have A Nice Day! Ford 292 & Cruise-O-Matic From Ford '64 F100
02-10-2012, 11:40 AM | #31 | |
02-10-2012, 05:38 PM | #32 |
56 custom
neat picture in post #24! good job redondo. what's manual say that tranny is? everything looks just like mine except cooler on mine is flat not angle up. the line #3 is above where it says 'oil cooler'. can't see front two because bracket in way. 56 custom by the way did YOU ever find tag on oil pan bolt or oval tag riveted on? Have A Nice Day!
02-10-2012, 06:50 PM | #33 |
All american boy, I havent found anything yet. I am trying to make room in the garage to get to my stuff.
02-10-2012, 08:34 PM | #34 | |
If you have a modulator on the back of the box it is not a Fordomatic. It is almost certainly a Cruisomatic which were also three speed autos. The best option for an auto which is relatively cheap apart from the FOM is to adapt a FMX to the Y block. You can use FOM bellhousing and late flywheel and have the best of everything. My experience of FMX's is that they are almost indestructible. Here in Oz our 59 - 60 Tank Fairlanes used a two speed Cruisomatic which was awful to say the least. This chart should help to identify what you have, bearing in mind that the Fordomatic does not have a modulator.
Regards
Rick West Australia 1958 Ford Mainline Utility, 1955 Ford Tudor Sedan Quote:
02-10-2012, 09:03 PM | #35 |
Rick, thanks for the illustration. How will I know if my trans has a modulator and what do they look like?
02-10-2012, 09:32 PM | #36 | |
The modulator is a small cylinder with a hose connection point attached to the back of the trans just above the oil pan. The steel line coming out of it, which will be about 1/4" diameter connects either to the manifold vacuum port or the base of the carb. It senses manifold vacuum and affects the way the gears shift.
Regards
02-10-2012, 09:52 PM | #37 |
Rick do you by chance have a picture of one of these?
02-11-2012, 12:30 AM | #38 | |
Here is a picture of a vacuum modulator. Some though not all cruiseomatics had these.
Here are a couple of ID charts for early Ford autos. Hopefully all this makes it easier for you. Regards
02-11-2012, 12:53 AM | #39 |
Rick you are the man!!!! I will post some pics. I just rolled the truck out.
02-11-2012, 12:36 PM | #40 |
Here are some pics of the original trans
http://i721.photobucket.com/albums/w.../oldtrans1.jpg What is this line that I am pointing at? This is the long hose that I dont know where it goes http://i721.photobucket.com/albums/w.../olftrans6.jpg Last edited by 56 ford custom; 02-11-2012 at 12:44 PM. |
