Go Back   The Ford Barn > The Swap Meet > Wanted > Late V8
Old 03-15-2024, 04:36 PM   #1
Avater
Avater's Avatar
Default Ford Y Block Ram Horn Exhaust
City: Glastonbury
State: Connecticut
Looking for a Ford Y block Ram Horn exhaust manifold. Hoping someone has one kicking around because I thought I had a pair until I discovered a hole in one of them. There's whole long story I won't trouble you with.
From what I understand, these came in the Ford C (COE) series trucks on 292 engines from 1957-1963. The bolt holes that mount these on the engine are all in one straight line.
Some C series had larger engines based on the Lincoln design and these ram horns are different the bolt holes on them are on the diagonal on each of the ports,
Only need one but would be happy to buy a pair if you have it.
Thank you!
Pete
Avater is offline   Reply With Quote
