Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 03-02-2024, 03:14 PM   #1
Steve Ferguson
Default Blinkers
Where do you start trouble shooting a problem with blinkers when you have LED lights? When i put on the flashers, they all work. Rear brake lights work. But when I use the blinkers, only the left front blinker works.
Steve Ferguson is offline   Reply With Quote
Old 03-02-2024, 07:33 PM   #2
paul2748
paul2748's Avatar
Default Re: Blinkers
Signal lights require a special flasher for LED's because the draw from LEDs is not enough to make a standard flasher work
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-02-2024, 11:17 PM   #3
Steve in Denver
Steve in Denver's Avatar
I have a 12 volt system in my '36 with LED bulbs. I use the Novita EP34 flasher, from Advanced Auto. There is probably something similar for 6 volt.
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 03-04-2024, 03:17 PM   #4
Steve Ferguson
Thank you Paul, I will check that out.
Old 03-04-2024, 03:17 PM   #5
Steve Ferguson
Thanks Steve, I am checking that out
