Old 03-03-2015, 09:29 PM   #1
epw1949
Default 1934 upper radiator hoses
I am putting a 59 type engine in a 34 car using the 34 radiator.i know that several thousand people have done this before.my question is,does any one make a upper radiator hose to fit,or what has others done to make this plumbing look decent? Any and all help will be greatly appreciated. Thanks e.p.w.
epw1949 is offline   Reply With Quote
Old 03-03-2015, 09:51 PM   #2
JSeery
JSeery's Avatar
Default Re: 1934 upper radiator hoses
Do you already have the radiator? When I had my radiator made I had them bring the inlets straight back so that is easier to plumb to the heads.
Old 03-03-2015, 10:05 PM   #3
epw1949
JSeery,yes I do,its the original reconditioned.That was a great idea.Thanks E.P.W.
Old 03-03-2015, 10:53 PM   #4
JSeery
JSeery's Avatar
Well, you are going to have to go with the "S" configuration. LOL
Old 03-04-2015, 08:29 PM   #5
epw1949
Btt
Old 03-04-2015, 09:15 PM   #6
Deuce Bob
Deuce Bob's Avatar
Hi I used a Carquest hose #23040 its made by Gates. It is an S shaped hose I cut to fit and worked out great. send me your E-mail and I can send you a picture. Bob
Deuce Bob is offline   Reply With Quote
Old 03-04-2015, 09:26 PM   #7
JSeery
JSeery's Avatar
I can add a couple.
Old 03-04-2015, 09:49 PM   #8
JSeery
JSeery's Avatar
Another one.
Old 03-05-2015, 08:09 AM   #9
jimTN
You can take a stock 37 hose, cut it in the center, turn one end and insert a pipe between the two cut ends and it fits like it was made for it.
