Old 02-16-2023, 11:06 AM   #1
47fordor
Default 16x6.00 Rims
I have a '47 and '48 Ford and both are missing their spare tires. Anybody know where I could get a 16x6.00 Rim? Yes, I know this would best be addressed in The Swap Meet but, since this is first I've logged in in about 5 years, I don't have the prerequisite 10 posts to post there and, for some reason, I don't have permission to reply to the adds that are already there.
47fordor is offline   Reply With Quote
Old 02-16-2023, 11:15 AM   #2
47fordor
Default Re: 16x6.00 Rims
Ok, I'm confused: now it allowed me to post in swap meet. ????
Old 02-16-2023, 11:22 AM   #3
Kube
Kube's Avatar
16" x 6"... By 4 1/2" perhaps? How are you measuring the width?
Old 02-16-2023, 12:33 PM   #4
1942deluxe
1942deluxe's Avatar
Timely post. I just bought a rim for a spare tire yesterday for my 42 and it measures 4 1/2 inches. When I look in the "green bible" it lists the 11A 1015 rim for 41-48 cars at 4". It then lists 8C 1015 for 42-47 commercial with a 4 1/2 width but compatible with 600 X 16 or 6.50 X 16 tires. Appears to be same bolt pattern but I haven't tried it yet. Anybody have any experience with this?
Old 02-16-2023, 01:11 PM   #5
Tim Ayers
I am no parts # expert, but I believe '40-early '41 16" rims were 4". Late '41-'48 car and I believe '48-'49 F-1 P/U's had 4.5" 16" rims. To confuse it even more, Lincoln Zephyr had a 16" X 5" rim that is very desirable to hot rodders for rear runners.
Old 02-16-2023, 01:22 PM   #6
Newc
Newc's Avatar
Watch out for the lug nut holes construction . 40/41 had 'innies' while later wheels had 'outies'. It is all about the length of the hub's wheel mount studs, short 40/41 or so. You can end up with the lug nut only HALF onto the threads!! Newc
Old 02-16-2023, 01:30 PM   #7
cas3
From my experience, when looking at the inside of a bare wheel, the ones with the drop center being square are generally 4", and the ones with the drop center having a slope on one side are generally 4 1/2". And, later pickup wheels that are 5" are quite a bit heavier when you pick one up.
Old 02-16-2023, 01:46 PM   #8
47fordor
I guess I should have said: rims for 16x6.00 tires. I've never checked the actual width of the rims (never occurred to me). Of course, since all my rims have tires on them, it would be difficult to measure them.
Old 02-16-2023, 02:15 PM   #9
alchemy
alchemy's Avatar
Come over after work and I can set you up.
alchemy is offline   Reply With Quote
Old 02-18-2023, 07:44 AM   #10
PeteVS
PeteVS's Avatar
So, where and when did the 15 x 5 rims (with "innie" nubs) come into being?
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 02-18-2023, 11:00 AM   #11
oldskool
oldskool's Avatar
i have one 4 sale 16x4.5 good shape where are you located
oldskool is offline   Reply With Quote
Old 02-18-2023, 11:40 AM   #12
cas3
Well, that beats up my theory, square drop center, yet 4.5 wide. That wheel looks in good shape.
Old 02-18-2023, 11:46 AM   #13
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 02-18-2023, 05:49 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Generally & for the most part, your theory is correct. First pic is 4" wide, and second pic is 4-1/2" wide. One more exception is the 3-1/2" wide 60 HP wheel of 1940 at BOTTOM. They have the square drop center.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 02-18-2023, 05:53 PM   #15
Lanny
Lanny's Avatar
cas,,, I'm guessing that a 4.5" wide wheel with the vertical drop center
is probably for a '40-'41 Station Wagon.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 02-21-2023, 11:27 PM   #16
alchemy
alchemy's Avatar
I've got a ton of old Ford steel wheels and I've never seen a straight dropped rim that was 4.5" wide. My understanding was the straight drop was a 1940 wheel, then they made the taper dropped 4" starting in 1941. But if a straight drop was made in 1940 for a woodie, then that's a pretty rare wheel so that's probably why I've never seen one.
Or, oldskool could have measured his wrong.
Old 02-21-2023, 11:33 PM   #17
47topless
47topless's Avatar
Or, oldskool could have measured his wrong.[/QUOTE]
careful!
47topless is offline   Reply With Quote
Old 02-22-2023, 12:22 AM   #18
Lanny
Lanny's Avatar
alchemy, curious how the width of some of your wheels, differ in the lugnut hole
area ?
Here are 2 pix of the lugnut area of 1940's era Ford wheels...
Old 02-22-2023, 09:22 PM   #19
alchemy
alchemy's Avatar
I've never paid much attention to see if wheels were innies or outies. If I have time this weekend I'll pull some off the rack and see if I can narrow down a timeframe or size comparison for the two varieties.
