02-08-2023, 06:35 PM | #1 |
Seems to run on 3 cylinders
1930 coupe .80 over bore, tillison carburetor, stock head, 160 thermostat, no air filter. Car runs great after short warm up. When I put coupe up, I run it out of gas with shutoff valve. Next time I start it, after about 30 seconds of fuel valve opening, the car seems to have a dead miss for about two minutes then it runs great. At start, GAV one full turn, throttle couple of notches down, advance 9-10 a clock after start. Any ideas, are just do not fool with it.
02-08-2023, 07:46 PM | #2 |
Re: Seems to run on 3 cylinders
Do you use Marvel Mystery Oil in your gas?
I would add some, and as the doctor would say, “call me if you don’t feel better”. Enjoy. |
02-08-2023, 08:06 PM | #3 |
Morning sickness caused by a sticking valve. Marvel Mystery oil usaualy frees them up.
02-08-2023, 08:07 PM | #4 |
How many miles on the engine? Maybe a sticky valve?
02-08-2023, 09:22 PM | #5 |
A little off topic, but an old timer told me a Model A will get you home on one cylinder...
He said if you disconnect the others, a well-tuned one will run on cylinder 1. Not sure of the significance of cylinder 1. But I will sure try it when/if I get mine running... Mike Houston, TX |
02-08-2023, 09:57 PM | #6 |
02-08-2023, 09:58 PM | #7 |
www.whidbeymodelaclub.com |
02-08-2023, 10:21 PM | #8 |
Have about 4000 miles on engine, just started using mmo about two tanks ago. I will try not to run it out of gas on shutdown. Thought it might be a valve, but has not always done that.
02-09-2023, 12:31 AM | #9 |
Like the guy said when his hose died, "First time he's ever done THAT"
the "Ace" mechanic |
02-09-2023, 07:07 AM | #10 |
Locate the one cylinder that is apparently missing by shorting out spark plugs one at a time. Take a compression check when cold. Best to use a compression gauge but a low tech method is to hand crank slowly to see if there is any cylinder offering less resistance.
02-09-2023, 07:25 AM | #11 |
Old shop saying “if you think it’s fuel issue it’s most likely ignition, if you think it’s ignition it’s most likely fuel”
I love the “get you home on one cylinder” stories, .. folks beat the hell out of the car when you could buy one for 5 bucks all kinds of tales arose from that time, most occurred a day before the car was thrown away for another one |
02-13-2023, 03:56 PM | #12 |
Thought I should get back to you all. Developed dead miss. Compression 53-60 lbs. Turns out it was a bad autolite plug with just over 4000 miles.
Side note: Spark plugs were very hard to remove, not sure what I put on them when installed but I thought it was anti-seeze. Sure this time. Running like a champ again. |
02-13-2023, 07:17 PM | #13 |
Thanks for the feedback
02-20-2023, 06:28 PM | #14 |
One more update. Changed Autolite plugs to Champion W16Y. Turns out pulling plugs and reinstalling them seemed to eliminate ploblem for awhile. Problem came back. Did some Google research and found that the W16Y plugs have the same properties inside the block, but the insulator above the head is longer on the Champion. My limited research lead me to believe these plugs are hotter. Running good again, will keep yall updated to changes if anything.
02-20-2023, 06:34 PM | #15 |
As others have stated, definitely a good idea to run some Marvel Mystery oil in it. You can get it just about any auto parts store, Wallmart etc etc. It WORKS. ATF works too.
02-20-2023, 06:36 PM | #16 |
Now you are onto something. Since you changed the plugs, let the Marvel Mystery Oil do some work. I bet things clear up. Don't over think it. I have over thunk it many times.
02-20-2023, 06:51 PM | #17 |
What's wrong with letting it run out of gas?
