Old 08-22-2022, 04:15 PM   #1
talwrench
Default Early 28 brake cross shaft
Started working on my 28 roaster p/u. I encountered a different cross shaft than I have seen. Its 3 pieces. My question is, dose anything belong between the shaft and the U clamp where it is supported out at the frame? I have lots of movement front to back. Should note this is early, no seperate shaft for emergency brake, the e brake pulls on the 4 wheel brakes.
talwrench is offline   Reply With Quote
Old 08-22-2022, 06:59 PM   #2
31Tudor
31Tudor's Avatar
Default Re: Early 28 brake cross shaft
No, it is just the shaft passing through the bracket. The shafts are typically worn right where they pass through the bracket. I recently had some welded up. Yes, this brake system was kind of floating to equalize between the 4 rods.
31Tudor is offline   Reply With Quote
Old 08-23-2022, 04:41 PM   #3
talwrench
Thanks 32 Tudor!!!!
Old 08-23-2022, 09:46 PM   #4
Jim Mason
Jim Mason's Avatar
File Type: jpg Screenshot_20220823-214430_Adobe Acrobat.jpg (69.7 KB, 36 views)
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 08-24-2022, 09:03 AM   #5
talwrench
Thanks for the diagram. Thats how my three piece brake shaft is, but I don' have seperate emergency brake system. Looks like all that is there is the support brackets at the frame. Going to rework them to take out the excess play.
Old 08-24-2022, 11:40 AM   #6
Jim Mason
Jim Mason's Avatar
There is alot of play on the early brakes. Equalization
File Type: jpg Screenshot_20220824-113735_Adobe Acrobat.jpg (67.3 KB, 20 views)
File Type: jpg Screenshot_20220824-113743_Adobe Acrobat.jpg (42.2 KB, 12 views)
Fwiw, jm.
