Old 03-31-2021, 05:40 PM   #1
oldbird55
Default 80 over rebuild
Anybody out there know where i can get pistons & rings for a 57 312 t bird 80 over.
oldbird55 is offline   Reply With Quote
Old 03-31-2021, 05:47 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: 80 over rebuild
Egge Machine
https://egge.com/part/egg-1000-l2018-8/
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 03-31-2021, 06:27 PM   #3
darrell
just wondering what size is your engine now.
darrell is offline   Reply With Quote
Old 03-31-2021, 06:32 PM   #4
oldbird55
312
Old 03-31-2021, 06:41 PM   #5
dmsfrr
dmsfrr's Avatar
Originally Posted by oldbird55 View Post
312
I'm guessing darrell was asking if it's been bored oversize already.
...because they usually aren't bored more than needed to clean up the cyl wall surface.
Old 03-31-2021, 07:02 PM   #6
Daves55Sedan
Daves55Sedan's Avatar
Don't know where I saw it, but it's been my understanding for the past many decades that 60 is the maximum overbore size for a Y-block. Beyond that exposes the cylinder wall to danger of busting through to the water jacket.
Old 03-31-2021, 08:15 PM   #7
dmsfrr
dmsfrr's Avatar
The machine shop I've been using here inspected an extra 312 block I've got, it's already 60 over. The head machinist/owner did some extra looking and finally found an 80 over set of pistons & rings and said he'd be comfortable rebuilding it at that size.
It's an EDB-E with a January '58 date code if that makes a difference.
Some years of blocks may tolerate that amount of over-bore better than others, I don't know.
Old 03-31-2021, 08:58 PM   #8
darrell
the early blocks suffered less from core shift.
Old 03-31-2021, 09:22 PM   #9
Dobie Gillis
Huh?
Old 04-01-2021, 12:39 AM   #10
KULTULZ
KULTULZ's Avatar
Arrow Re: 80 over rebuild
Originally Posted by Dobie Gillis View Post
Huh?
Thicker and heavier castings. Old school.
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 04-01-2021, 04:12 AM   #11
darrell
checking between the cylinders the old blocks were more even.less cylinder stagger.the later c1 and c2ae blocks were a lot worse.
Old 04-01-2021, 06:51 AM   #12
Dobie Gillis
My "Huh?" response was to a spam post in what appeared to Russian. The moderator must have removed it. I understand about bore limits and core shift.
Old 04-01-2021, 09:55 AM   #13
KULTULZ
KULTULZ's Avatar
Post Re: 80 over rebuild
Then that explains it ...
Old 04-01-2021, 07:32 PM   #14
chain drive
i always wonder about the thickness of walls bought a ultrasonic tester you will be done wondering about the block and learn alot
chain drive is offline   Reply With Quote
Old 04-03-2021, 12:43 AM   #15
frnkeore
frnkeore's Avatar
Sonic testing is the best way to proceed.
FYI, regarding racing applications, John or Geoff Mummert and Joe Crain, don't recommend boring a 312 block, more than .040. It's been said that the cylinder cores are the same on on the 292 & 312. I'm not a Y-block guy so, I have no experience with them, but, Geoff & Joe, have a lot of experience with them. There is one more that can be consulted, Ted Eaton:
https://www.eatonbalancing.com/2000/...cing-articles/
Any of those 4 people, can tell you what is what, on a Y-block, it's how they make there living.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 04-03-2021, 07:48 AM   #16
KULTULZ
KULTULZ's Avatar
The CASTINGS are the same but each receives differing machining protocol, the 312 being much less accurate. The trick is to find a 292 block and build it to 312 spec., especially if HP.
Old 04-03-2021, 10:59 AM   #17
55blacktie
I think somebody has been drinking some of that corn.
55blacktie is offline   Reply With Quote
Old 04-03-2021, 11:13 AM   #18
KULTULZ
KULTULZ's Avatar
Question Re: 80 over rebuild
Would you care to elaborate or even just reply in a somewhat knowledgeable manner?
Old 04-04-2021, 02:39 AM   #19
KULTULZ
KULTULZ's Avatar
Guess not ...
Let's look at this again. You somehow think my statement above about the Y-BLOCK 292/312 CASTING is not correct?
If I am wrong, I am wrong. But bring facts, not potshots.
Now, can you provide anything substantial to the contrary or will I be forced to post new SEX JOKES that seem to disturb you so badly ...
Old 04-05-2021, 04:45 PM   #20
KULTULZ
KULTULZ's Avatar
I guess 'ol blacktie got held up yesterday in worship and bible class. Those terrible sex jokes he stumbled across here must have really worn him down.
Any who, for any other doubters -
SOURCE - http://www.ford-y-block.com/Block%20identification.htm
File Type: jpg FYB - ENGINE - 1956-57 292-312 CASTING ID.jpg (20.9 KB, 8 views)
