Old 10-24-2020, 06:53 PM   #1
richard crow
Default spindles
what is the differance between 37-41 41-48 spindles can 41-48 be used on a model a axle to mount hydl brakes
richard crow is offline   Reply With Quote
Old 10-24-2020, 07:11 PM   #2
rich b
rich b's Avatar
Default Re: spindles
Later model spindles have larger (taller) bushings along with a different appearance. They will fit a Model A axle.
rich b is offline   Reply With Quote
Old 10-24-2020, 09:11 PM   #3
Fordors
As rich b said, yes they can be used on a Model A axle, but be advised that the ‘37-‘41’s (also known as round backs) use a king pin 5 1/2” long and the ‘42-‘48 spindles (square back) take a 6” long k/p. You will want the correct k/p set for the spindles you choose.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 10-25-2020, 12:06 AM   #4
Randy in ca
Randy in ca's Avatar
Here's a picture I've posted a couple of times before that shows the differences that others have mentioned. Basically the 1942-48 version are beefier than the 1937-41 but otherwise interchangeable.
Randy in ca is offline   Reply With Quote
Old 10-25-2020, 04:39 PM   #5
richard crow
all that answered thanks for the great info
Old 10-25-2020, 05:23 PM   #6
Mart
Mart's Avatar
The later one have a generally square appearance, the 37-41 are commonly called roundback.
Would it be correct to assume the later ones wear more slowly due to the longer bushes? (Everything else being equal). Probably made longer to compensate for the vehicles getting heavier???
