10-24-2020, 05:27 PM | #1 |
1939 ford V8-60 truck 3 speed transmission questions
Pictured is a 1939 ford pickup V9-60 transmission.
Will the later type gears fit in the case without clearance issues like a 48 case? Obviously this one had been out in the weather. The other question is the odd looking thow out bearing hub ? Is it unique to the V8 60 or swapped into this from something else? |
10-26-2020, 04:17 AM | #2 |
Re: 1939 ford V8-60 truck 3 speed transmission questions
Had one of these a few years ago. Looked like regular gears would go right in. If I remember correctly there were thrust washers at both ends of the cluster gear.
10-26-2020, 04:34 AM | #3 |
Mart. |
