Old 10-22-2020, 09:23 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Differential Gear Ratio Determination
Without taking anything apart, and without peeking at the speedometer drive gear case, what is your process to physically determine the differential gear ratio?
Bob Bidonde
Old 10-22-2020, 09:55 AM   #2
DBSHELTON
Default Re: Differential Gear Ratio Determination
Mark front pulley, mark tire, roll tire one revolution and count the engine revolutions.
DBSHELTON is offline   Reply With Quote
Old 10-22-2020, 10:32 AM   #3
Y-Blockhead
Y-Blockhead's Avatar
To add; with transmission in 3rd gear.
Old 10-22-2020, 11:10 AM   #4
DBSHELTON
Yep, I left that out.
Old 10-22-2020, 11:46 AM   #5
Jim/GA
Jim/GA's Avatar
If you don't want to roll the car forward (don't have space, etc.) you can jack up one wheel in the back, mark the tire, and count how many revolutions of the crankshaft it takes to make that one tire go around fully 2 times (not 1) with the transmission in High gear. Use the hand crank and have someone watch the tire while you crank (it is easier with all of the spark plugs out).
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 10-22-2020, 11:51 AM   #6
David R.
That is what I did on my AA
David R. is offline   Reply With Quote
Old 10-22-2020, 12:32 PM   #7
TerryAtkins
TerryAtkins's Avatar
RE: Differential Gear Ratio Determination
EASILY find Differential Ratio and Compute engine RPM @ a given speed vs the ratio.
Jack up rear end just enough for1 wheel to clear & support with jack stand.
Remove top filler plug, wipe oil off one ring gear tooth and mark it with a dab of white paint. Rotate a tire counting the number of ring gear teeth.
34 = 3.78:1
37 = 4.11:1
39 = 4.56:1
Also see http://www.fordgarage.com/pages/rearaxleratios.htm
Compute your Engine RPM at a given speed with your axle ratio.
Assumes model A is in third gear (1:1 ratio) and not in overdrive if you have one.
Engine RPM is egual to:
Speed in MPH times Axle Ratio times 336 Divided by the Tire Height. 336 is a constant.
Example: 55MPH, axle ratio 3.78, 30 inch tire height gives Engine RPM of 2,328.48
TerryAtkins is offline   Reply With Quote
Old 10-22-2020, 12:59 PM   #8
DBSHELTON
I like that one Terry!
Old 10-22-2020, 01:42 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
I mark crankshaft pulley, on level ground, put in 3rd with valve stem up on tire, roll car forward till valve stem up again while counting revolutions, --- 3-3/4 about= 3:78
4 plus a little = 4:11, 3-1/2 =3:54 , usually I grab front wheel to move car so I can watch pulley, and feel position of valve stem
Old 10-22-2020, 01:48 PM   #10
Benson
Benson's Avatar
Originally Posted by terryatkins View Post
re: Differential gear ratio determination
easily find differential ratio and compute engine rpm @ a given speed vs the ratio.
34 = 3.78:1
37 = 4.11:1
39 = 4.56:1
also see http://www.fordgarage.com/pages/rearaxleratios.htm
compute your engine rpm at a given speed with your axle ratio.
Assumes model a is in third gear (1:1 ratio) and not in overdrive if you have one.
Engine rpm is egual to:
Speed in mph times axle ratio times 336 divided by the tire height. 336 is a constant.
Example: 55mph, axle ratio 3.78, 30 inch tire height gives engine rpm of 2,328.48
fyi:
3.54 = 11 39
4.56 = 9 41
Benson is offline   Reply With Quote
Old 10-22-2020, 02:17 PM   #11
TerryAtkins
Just passing it on.
Found it somewhere on on one of the forums.
