Old 10-22-2020, 08:56 AM   #1
billybronco1
Default Wiring question
Do the wire connectors on the wiring harness for example the headlights pull apart or are those crimp connections?
1936 Ford Model 68
billybronco1 is online now   Reply With Quote
Old 10-22-2020, 09:05 AM   #2
JSeery
JSeery's Avatar
Default Re: Wiring question
Ford used what are referred to a bullet connectors. And yes, they pull apart.
JSeery is online now   Reply With Quote
Old 10-22-2020, 09:08 AM   #3
19Fordy
19Fordy's Avatar
Be sure to use dielectric grease when connecting those bullets. They oxidize very easily and easily loosen.
Old 10-22-2020, 09:17 AM   #4
billybronco1
So they should pull apart?
1936 Ford Model 68
Old 10-22-2020, 09:36 AM   #5
51woodie
51woodie's Avatar
If you have original wiring, they do pull apart. The connectors have a "spring loaded" sleeve with ridges inside to "lock" into the groove in the male connector and a rubber cover over the sleeve. Over the years, the rubber becomes very hard, and will sometimes make it difficult to pull the connector out of the sleeve. Dennis Carpenter has the wiring connectors in their catalogue.
51woodie is offline   Reply With Quote
Old 10-22-2020, 10:29 AM   #6
19Fordy
19Fordy's Avatar
billybronco1: Yes, they pull apart. Pull one apart and see how they are made. Very "weak" technology but good enough back in those days. Unless you desire a 100 point restoration, you may want to consider installing more modern and secure connectors. Use shrink tubing also, if possible. Lots of good videos on You Tube. Here's a start.
https://www.google.com/search?q=how+...hrome&ie=UTF-8
Old 10-22-2020, 06:54 PM   #7
billybronco1
Thanks for the info. I have fog lights on my car now, the last guy tried to use them for directionals, will not work because they draw too much. I want to hook the fog lamps up for day time driving lights, when hooked direct to 6v they are bright. I want to use the parking lights inside the headlight cans for the directionals. Also want to put in led tail lights as well as a third brake light.
1936 Ford Model 68
Old 10-22-2020, 07:48 PM   #8
Jacques1960
Jacques1960's Avatar
You might want to look at the wireless directional package made by Egypt Garage; Leno’s workaround of choice for simple addition of directional
No jobís done Ďtil itís all done
Jacques1960 is offline   Reply With Quote
Old 10-22-2020, 07:51 PM   #9
billybronco1
I already have the directionals installed and all the wires have been run so I just want to change a few things
1936 Ford Model 68
Thread Tools
Display Modes
