Old 09-19-2020, 04:32 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 59a inlet manifold vacuum line fitting 1946.
Have broken the banjo fitting bolt for connecting vacuum line from distributor to manifold. Located just below carb. Wondering what is the thread size?
The banjo fitting is hard to come by?
Thanks,
Phil
Phil Gillespie is offline   Reply With Quote
Old 09-19-2020, 04:45 PM   #2
Kube
Kube's Avatar
Default Re: 59a inlet manifold vacuum line fitting 1946.
Originally Posted by Phil Gillespie View Post
Have broken the banjo fitting for connecting vacuum line from distributor to manifold. Located just below carb. Wondering what is the thread size?
Thanks,
Phil
Phil, If you can't find one, let me know. I have some. The banjo fitting was authentically integral (soldered) to the steel vacuum tube.
Do you have the special vacuum fitting that attaches the banjo to the manifold? The one that the wiper hose connects to?
Old 09-19-2020, 04:58 PM   #3
Phil Gillespie
Yes I do have that one with the wiper connection. However have since gone with electric wipers. Its the bolt for the banjo fitting i'm looking for. My banjo fitting is integral with the steel tube.
Appreciate your assistance and advice.
Phil NZ
Old 09-19-2020, 05:25 PM   #4
35fordtn
35fordtn's Avatar
Phil,
Up to you, but with todayÂ’s fuels the vacuum brake line is really not needed. On my driver cars I have the hole plugged
35fordtn is offline   Reply With Quote
Old 09-19-2020, 08:48 PM   #5
Phil Gillespie
Originally Posted by 35fordtn View Post
Phil,
Thats why I would be keen to know thread size for the connection at manifold.
1/8" gas/bsp??
Phil NZ
Old 09-19-2020, 09:36 PM   #6
35fordtn
35fordtn's Avatar
Phil, I can measure one when I get to work on Monday and report back.
Old 09-19-2020, 10:22 PM   #7
Phil Gillespie
Thank you that would be great.
Phil NZ
