Old 11-24-2018, 03:21 PM   #1
VeryTangled
VeryTangled's Avatar
Default 21 Stud block, stud location dimensions?
Hi Everyone. It came up in conversation recently... Does anyone have the x & y dimensions of the 21 stud block's, stud locations? Something like a parts drawing for a cylinder head should work. Simple, right?
File Type: jpg 1280px-The_Valve_In_Block_Design_or_Flathead_Block.jpg (77.6 KB, 46 views)
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 11-24-2018, 03:55 PM   #2
Lawrie
Lawrie's Avatar
Default Re: 21 Stud block, stud location dimensions?
I dont have the 21 stud dims ,but have the 24 stud ones.
let me know if you need these.
Lawrie
Lawrie is offline   Reply With Quote
Old 11-24-2018, 04:13 PM   #3
bobH
they are the same (24 & 21) except for the bottom row. If you are looking for 'approximate', any of us could measure the bottom row for you.
bobH is online now   Reply With Quote
Old 11-24-2018, 04:33 PM   #4
Jack E/NJ
Jack E/NJ's Avatar
As I understand it, the piston centers and reddish-blue studs in the image below are identical to the 24-stud. The fully-blue studs are different. Distances between studs could be calculated relative to the 24 stud dimensions and reference-scale to the image. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 11-25-2018, 10:54 AM   #5
deuce_roadster
deuce_roadster's Avatar
The Green Bible lists all the studs and their exact length. A head gasket would give you the spacing.
Old 11-25-2018, 07:07 PM   #6
Talkwrench
Talkwrench's Avatar
Anyone have the length of studs and in which position they go on a 21 studder?
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 11-25-2018, 08:29 PM   #7
Lawrie
Lawrie's Avatar
They are different depending on what heads you use, just ask Danny from north QLD
Lawrie
Old 11-25-2018, 09:06 PM   #8
RobR'35
RobR'35's Avatar
I too would be interested in length of studs and which position on a 21 stud block. I think there's a length difference in either aluminum or cast heads....?
RobR'35 is offline   Reply With Quote
Old 11-25-2018, 09:24 PM   #9
Talkwrench
Talkwrench's Avatar
Yes I think I remember him saying something like that when I was with him.. Had a nice set of aftermarket [pump in head] heads..
Im talking standard cast iron..
Old 11-26-2018, 04:42 AM   #10
Lawrie
Lawrie's Avatar
Rob ,look in the green bible,it may show the stud lengths.
If not let me know, I have a set od NOS cast iron heads in my shop.
Lawrie
Old 11-26-2018, 09:05 AM   #11
JSeery
JSeery's Avatar
Well, I'm sure the folks making parts (such as heads, gaskets, etc) do, but it might be difficult to get them to part with the information. There was a guy who posted on the Barn a few years back that was working on a 3-D model of a flathead engine. He might have that information but don't remember what name he posted under (it was Flysafe, but his last login to the Barn was in Aug 2015). If there is a real desire to have the data, take a head or block or whatever to a shop with the digital equipment to measure the positions. For quick and dirty use a head and transfer punches to mark locations.
The Ford archives should have the original head/block drawings.
Old 11-30-2018, 10:21 PM   #12
Yoyodyne
Yoyodyne's Avatar
If you can work with a DXF or Autocad file, PM me your email address and I'll send you some files. I asked here a couple times and no one had the data so I CMMed some 24 and 21 stud head gaskets and turned the data into digital files. Not the same as having genuine original Ford blueprints, but the holes are symmetrical and consistent and good enough to make parts from. The image Jack E/NJ posted is one I posted here.
Yoyodyne is offline   Reply With Quote
Old 12-01-2018, 01:52 AM   #13
Lawrie
Lawrie's Avatar
I have the XY dims for the 24 stud
Lawrie
Old 12-01-2018, 10:56 AM   #14
VeryTangled
Thanks to everyone who contributed!
-Jeff H
Old 12-01-2018, 11:54 AM   #15
Yoyodyne
Yoyodyne's Avatar
How would someone (like me) go about getting them from there?
Old 12-01-2018, 05:14 PM   #16
SUHRsc
SUHRsc's Avatar
Lawrie and yoyodyne if either of you wouldn't mind sharing it would be much appreciated my email is Zach(at)suhrsc(dot)com
-WANTED-
Pre-War Speed Equipment
Davies or Morrison Intake Manifold
77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads
SUHRsc is offline   Reply With Quote
Old 12-02-2018, 04:18 PM   #17
VeryTangled
Everyone, It was Zach who was a part of the conversation that got me to start the discussion. Thanks again everyone for the helping hands!
-Jeff H
