Old 04-25-2018, 06:02 PM   #1
Ross F-1
Ross F-1's Avatar
Default Cornhead grease question
I am going to try Cornhead grease in my steering box, having failed to get it to stop leaking. But it occurs to me that it may not keep the sector gear bushings lubed. Does anyone have long-term, long mileage experience using the grease?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 04-25-2018, 06:13 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Cornhead grease question
Lots of folks use it in steering box. Read about it here. High praises.
https://www.fordbarn.com/forum/showt...e+steering+box
Old 04-25-2018, 06:35 PM   #3
3twinridges
It seems like the exhaust manifold would be close enough to add enough heat to help liquify it enough to seep lube into those bushings.
JB
3twinridges is offline   Reply With Quote
Old 04-25-2018, 06:47 PM   #4
Joe Immler
I also had seepage from my '41 steering box. I use Cornhead grease now and am very pleased. no leak or seepage at all.
Joe Immler is offline   Reply With Quote
Old 04-25-2018, 08:14 PM   #5
Krylon32
I have it in the 37 Hudson box in my deuce pu. No leaks and works in all kinds of weather. I just got done putting it in 54 center pivot irrigation gear boxes. Pivot dealer says it virtually eliminates gear box failure plus doesn't leak.
Krylon32 is offline   Reply With Quote
Old 04-25-2018, 09:13 PM   #6
JSeery
JSeery's Avatar
Now there is some good feedback!
Thread Tools
Display Modes
