Old 02-13-2017, 12:37 PM   #1
cmarion
Default Weber carb
What jets are on the Weber progressive 32/36 used on flat head model A eng.?
cmarion is offline   Reply With Quote
Old 02-13-2017, 01:05 PM   #2
briphaeton
Default Re: Weber carb
I use the stock jets. Never had a reason to pull the top off the carburetor.
briphaeton is offline   Reply With Quote
Old 02-13-2017, 01:59 PM   #3
denis4x4
denis4x4's Avatar
Same here
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 02-13-2017, 02:27 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by denis4x4 View Post
Same here
OK, but these carbs are offered as O.E. & aftermarket on engines such as the V-6 Ford engine (2800cc - 170c.i.) all the way down to a 1600 cc VW coming in at a whopping 97 cubic inches. With a Model-A/B engine coming in just over 200 cubic inches, there is quite a bit of variation between venturi sizes and jetting. As I recall, the Model A carb is like 110 cfm ...yet there are 2 or 3 different venturi sizes that allow those Weber carbs to be like 220 cfm up to a 330 cfm. Jet sizes are also respondent in correlation to the venturi size. My point is you could very easily purchase a carb that is too small or too large for your Model-A.
Personally, if I were the OP I would contact the company that manufactures Weber carbs (I cannot remember their name but they are based out of California) and give them all the specs on your engine and let them give you a recommendation based on your engine combination for venturi size, idle & main jet.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-13-2017, 02:55 PM   #5
briphaeton
My Weber has been on since 1992. It's a DGV 5A with a manual choke. Average 25 mpg and better on several out of state tours, one 2000 mi and one 5000 mi tours. Brent is probably thinking about www.piercemanifolds.com/ in Morgan Hill CA.
Old 02-13-2017, 03:19 PM   #6
denis4x4
denis4x4's Avatar
The company is Redline in Gilroy CA. In as much as they are purchased as a package including the A intake and linkage designed to hook up to the stock throttle linkage, it stands to reason that the vendors are offering the correct package. In fact, I bought my set up from Bert's in Denver and had to return it to Redline to have a different fuel fitting installed. The techs at Redline assured me that it was correct out of the box for a 200 cid Model A engine.
Old 02-13-2017, 03:58 PM   #7
CarlG
CarlG's Avatar
When I bought my kit, it was written on the carb "Jetted for Model A". Kit included the manifold and linkage for a Model A as well.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-13-2017, 04:14 PM   #8
Jason in TX
Jason in TX's Avatar
This is what the "Jetted for Model A" version comes with.
...........Primary... Secondary
Idle........ 50 ............50
Main ......135...........135
Air..........165.......... 165
Pump.......50.........Blocked
Diagram below shows jet layout (not Model A jets)
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 02-14-2017, 12:19 PM   #9
cmarion
Thanks much
Old 10-01-2020, 11:09 PM   #10
TommyDfromGermany
Hi all together. I gotta bring this thread back up..
I'm messing around with a weber that i bought here on the barn.
It was supposed to be jetted for a stock A motor, but it is way off.
I bought the jets like "Jason in Tx" mentioned above, the carb is way too lean now, i think my problems now are venturi and emulsion tube size. Does anyone know the specs how these come on the "jetted for Model A" version. I have 3.5 venturis and a f50 main and f6 secondary tube.
Thanks a lot, greetings from Germany
TommyDfromGermany is offline   Reply With Quote
Old 10-02-2020, 09:29 AM   #11
Benson
Benson's Avatar
Denis,
See red above:
Since they replaced the fuel fitting ... are you running without a fuel pump?
I heard that these Webbers run lean when fuel tank gets down to 3/4 full if running gravity feed or too low fuel pressure.
Benson is offline   Reply With Quote
Old 10-03-2020, 08:54 AM   #12
denis4x4
denis4x4's Avatar
Originally Posted by Benson View Post
Denis,
See red above:
Running a fuel pump on both A's with the Weber 32/36 set up. Also use a fuel pressure gauge set at 3 PSI
Thread Tools
Display Modes
