Old 10-21-2020, 10:14 AM   #1
38 Conv
38 Conv's Avatar
Default Type under dash AC- heat unit used
Any pictures of universal type AC -- Heat unit under dash unit used in a 1955 Ford F-100-- besides Vintage Air in my Rest-O-Mode--Thanks
38 Conv is offline   Reply With Quote
Old 10-23-2020, 05:48 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Type under dash AC- heat unit used
If you are referring to air conditioning (AC) most options would be separate units. Since Ford only had heater options in the 50s F100 pickups then one of those options would work for heat & defrost. For AC a person would have to go to Vintage Air or some other under dash air conditioning system.
https://www.vintageair.com/surefit/c...54&model=F-100
This appears to be both heat and AC
