Old 10-20-2020, 06:57 AM   #1
cvicky
cvicky's Avatar
Default driveshaft yoke
proper drive shaft length
it appears less than 1/4 of yoke is in back of trans one inch on splines
lots of up and down play but doesn't leak
cvicky is offline   Reply With Quote
Old 10-20-2020, 09:20 AM   #2
40cpe
40cpe's Avatar
Default Re: driveshaft yoke
Some engines have been installed with motor mounts reversed. It locates the engine 2" froward from the correct position.
40cpe is online now   Reply With Quote
Old 10-20-2020, 05:57 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
Originally Posted by 40cpe View Post
Some engines have been installed with motor mounts reversed. It locates the engine 2" forward from the correct position.
I'd like to see how they got the engine front steady rest and transmission crossmember mount on.
I believe there is not more than 1" overall in the adjustments for the engine steady rest.
It seems like 2" forward would push your fan-blade into the radiator. If you took out the factory spacer between water pump pulley and fan blade, you only subtract less than one inch.
The Y-block in my '55 is all stock with original fan blade and spacer. You can barely stick an index finger between fan-blade and radiator.
Anyway, if the alcove for the mounting bolts on your side motor mounts are facing forward, they are installed backward. The bolts should be installed from the backside.
If so, could be that somebody has got a shorter driveshaft than the original, so the front yoke doesn't engage with trans output shaft as far as it should.
Old 10-21-2020, 07:56 AM   #4
KULTULZ
KULTULZ's Avatar
Exclamation Re: driveshaft yoke
very dangerous ...
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-29-2020, 10:30 AM   #5
cvicky
cvicky's Avatar
Mr driveshaft will modify my shaft
he says the slip yoke only needs enough play to get rear U joint in.
1/2 - 1"
Old 10-29-2020, 11:12 AM   #6
55blacktie
There has to be enough play to allow for rear axle movement.
55blacktie is offline   Reply With Quote
Old 10-29-2020, 12:42 PM   #7
KULTULZ
KULTULZ's Avatar
Post Re: driveshaft yoke
1/2 - 1"
Correct. Are you viewing the slip yoke with the car jacked up and the rear hanging? The slip yoke (with correct ride height) should go into the tail-shaft a little over the half length of the yoke.
The yoke slides in and out as the rear suspension contracts/expands.
It's in the SHOP MANUAL.
- WHY IS IT ... -
Old 11-11-2020, 08:31 PM   #8
cvicky
cvicky's Avatar
yes measured with rear axle on stands
