Old 10-05-2020, 12:42 PM   #1
Tod
Default Post or not?
Up until recent customers inquired about an iron 5 main block for use with their 5 main cranks, I have confined myself to aluminum 5 main blocks and regular 3 main blocks. But, since opportunity for quite a few 5 main iron blocks has presented itself, I went ahead last week and took advantage of some down time, due to an injured shoulder, and went to the foundry where we sampled the first iron 5 main block.
I was hesitant to post anything here, but I figured someone might have an interest. I had given no thought to cranks as the buyers already had them, but someone else asked if I might consider doing that also (mainly for use with aluminum blocks). I have made V8 cranks in the past and with my current foundry I can easily make a very affordable crank for these, even if the only 5 main blocks I choose to do are aluminum.
I only think about posting these pictures so those interested in 3 main blocks have a frame of reference as to what the 3 main blocks will look like from my new foundry. I may have even posted pictures of the most recent 3 main block and aluminum blocks, but the 5 main iron pictures are only on FaceBook at this point.
If anyone is interested, let me know. perhaps it would be best to do it only by email. You tell me.
Tod
Tod is offline   Reply With Quote
Old 10-05-2020, 02:27 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Post or not?
So post them! Just because we may not be going to buy one does not mean there is no interest in seeing the item. Esp the process that takes place to get something to market, the pitfalls and wins.
Old 10-06-2020, 06:21 AM   #3
Tod
OK, here you go. Since I only have 15-20 people after one of these iron blocks, the idea is to see what 3 main blocks will look like.
I even put a picture of one with an iron Thomas head in the mix.
Tod
Old 10-06-2020, 09:22 AM   #4
Charlville
Charlville's Avatar
@Tod Thanks for posting, very interesting
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 10-06-2020, 09:51 AM   #5
1930artdeco
1930artdeco's Avatar
If I didn't have a block lined up.....Aluminum is looking very good...Heck I may even still just go with your block.
Mike
1930 TownSedan (Briggs)
Still learning after all these years....
Old 10-06-2020, 09:55 AM   #6
GRutter
GRutter's Avatar
We have Terry's blocks (5 main, cast iron with crankshaft & connecting rods) nearing production release, and Tod's block (3 main cast iron or 5 main cast aluminum ?) at some stage of completion.
We have had a lot of info from Terry on the engineering that has gone into his block, in addition to his recent assembly and test run results.
Tod, can you provide a summary of where you are in the process?
GRutter is offline   Reply With Quote
Old 10-06-2020, 10:17 AM   #7
rotorwrench
rotorwrench's Avatar
I never thought I'd ever see stuff like this. It just blows my mind.
Old 10-06-2020, 10:32 AM   #8
Tod
I have posted quite a bit of information since I started this a while back, messing around starting in 2012, or so, while I did my normal workload. In 2014 I had a running engine. I imagine some people on here are unaware of that.
There is no process. I made one and had it running in 2 years doing it on the side. Since there was almost no interest I set it aside for the most part and focused on several cylinder head projects as I machine the normal workload. I can talk all day about details, but I prefer to just do what I do.
For the past 2-3 years I have been very busy making tooling for several customers and there is no shortage of means of income. I have made more things than I care to discuss in the last 6 years since my first engine fired up, including tooling up an airplane engine that took flight quickly. I have several antique car engine parts finished in that time also, for some people that bring older and difficult parts to me. I have an 8BA almost ready to go, but other things have demanded my time, so it sits more than I like.
Forgive me if that came across as abrupt, and frank, but there is more than enough from my keyboard, even on this forum. I will not go over it all again. I only posted these recent pictures for those interested in my 3 main blocks.
I should add that the vast majority of contact I have with people here is about new cylinder heads.
Tod
Old 10-06-2020, 10:33 AM   #9
Tod
I should be insulted. LOL. I know you know some of what I have been doing.
Tod
Old 10-06-2020, 01:03 PM   #10
GRutter
GRutter's Avatar
Tod -
Wow. I knew about your cylinder heads. Didn't know you were also doing blocks!
Thanks for all you do for our hobby.
Old 10-06-2020, 11:13 PM   #11
eagle
eagle's Avatar
I'm curious as to how much weight savings does the aluminum head and block give you?
Old 10-07-2020, 01:35 AM   #12
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
POST OR NOT
No, you should NOT have posted here and now. What's next? Discount coupons for your products?
Am I the only person that sees a tawdry attempt to move to the front of the line?
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 10-07-2020, 02:00 AM   #13
Ak Sourdough
Ak Sourdough's Avatar
Yes.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer.
Ak Sourdough is offline   Reply With Quote
Old 10-07-2020, 07:19 AM   #14
Tod
Mike
I posted pics of aluminum elsewhere. Did you see that info?
Tod
Old 10-07-2020, 07:21 AM   #15
Tod
A block and head by themselves would be around 1/3 the weight of iron. A little comes back in aluminum as the blocks need to be sleeved with ductile sleeves. I would have to go weigh a sleeve to tell you exactly how much.
Tod
Old 10-07-2020, 07:25 AM   #16
Tod
Tod -
PM me and I will set you up with more (video, machining pics, etc..) than you found out in this thread. All old news, to be sure, but you apparently have not seen it.
Tod
Old 10-07-2020, 07:32 AM   #17
Tod
Originally Posted by Richard in Anaheim CA View Post
POST OR NOT
Richard
Anaheim CA
Yeah, discounts for things, like package deals. Great idea!! Block package, plus cylinder head, intake, aluminum front cover, header, flywheel housing, and probably more things, all for one discounted price.
Thanks,
Tod
Old 10-07-2020, 11:12 AM   #18
Charlville
Charlville's Avatar
Thanks for the updates @Tod
Kevin Flood
West Berkshire UK
Old 10-07-2020, 12:39 PM   #19
Tod
You are welcome.
Tod
Old 10-11-2020, 10:43 AM   #20
Tod
OHV nearing completion. I will be making about a half dozen of these in iron next for some of the 5 main iron block customers.
Tod
