Old 10-04-2020, 07:35 PM   #1
Denali
Default Marvel Carburetors
So, I have 5 Marvel carburetors in my collection of Model A stuff. I am wondering if anybody knows where I can send them out to be rebuilt? Well, two of them anyway. Or does anyone know where I can get rebuild kit(s)?
Mark in Fairbanks Alaska
Denali is offline   Reply With Quote
Old 10-04-2020, 07:48 PM   #2
Harpkatt
Harpkatt's Avatar
Default Re: Marvel Carburetors
Try googling Renners Corner
Harpkatt is offline   Reply With Quote
Old 10-04-2020, 08:15 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
Yes, call David at Renner's Corner https://rennerscorner.com/carburetor.html. David is a good guy and will fix you up with what you need. He has rebuild kits and parts. He also has some used parts that are not listed so if you don't see it, ask. I just got a good used throttle shaft to replace my worn one.
Also check the slide show https://rennerscorner.com/slide-show--info.html for info on MarVel Schebler/Allstate/Johnson carburetors.
Old 10-04-2020, 08:21 PM   #4
wmws
Jim Bullock in Texas. JMACARBS.com The expert on Marvel Carbs
wmws is offline   Reply With Quote
Old 10-05-2020, 06:58 AM   #5
41plym
x2 on Jim Bullock
41plym is offline   Reply With Quote
Old 10-05-2020, 08:48 AM   #6
sphanna
sphanna's Avatar
Jim Bullock. x3. vey satisfied with my marvel for him.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 10-05-2020, 09:03 AM   #7
1930artdeco
1930artdeco's Avatar
Renners no longer rebuilds carbs. But they still sell parts for them.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-05-2020, 09:05 AM   #8
30 Closed Cab PU
Jim Bullock x4 - bought a rebuilt from him this year, very satisfied, If rebuilt by him they are tested/use flow tested jets, runs a ton better then the 2 rebuilt zeniths I also have. Since they are tested they have the Gas line adapter fitting on them. Simply swap in , form your gas line for the Marvel - maybe adjust the idle jet where you want. He sends instructions with the carb. Quick turnaround. My truck will now idle at 420 rpm which it previously would only idle smoothly down to 500 rpm, never stalls, seems to run better/smoother.
Old 10-05-2020, 03:56 PM   #9
Aretino
Aretino's Avatar
Jim x 5.
Aretino is offline   Reply With Quote
Old 10-06-2020, 01:44 PM   #10
RB_Nielsen
RB_Nielsen's Avatar
Jim x6
RB_Nielsen is offline   Reply With Quote
