Old 10-01-2020, 06:41 AM   #1
Steve Rinaldo
Default Radius Ball Service
I have just finished doing a service on my 1930. One of the things I did was to tighten up the two radius ball nuts. I checked a lot of the books and previous post about the proper procedure and found a bunch of ways to do it.. The reason for this was I had a slight steering wheel shake between 50-55 mph. I tightened the nuts until they hit the sleeve and then backed them off until I could insert the cotter pin. I drove the car and the shake was gone. My question, is the procedure that I used the normal one that is used?
Thanks, Steve
Steve Rinaldo is offline   Reply With Quote
Old 10-01-2020, 07:14 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Radius Ball Service
If it worked I wouldn't worry about it...............
Paul in CT
Old 10-01-2020, 09:13 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Paul in CT
Until it cracks/breaks the bottom of the clutch housing case.
There is a lot that is assumed in this area. If the radius rod ball is worn out of the 1.500" diameter, tightening seems the prudent thing to do however the fall grows in diameter as the radius rod is rotated. Overtightening allows the radius rod ball to potentially bind during the front-end travel arc. Hit a drastic bump with the cap overtightened and I have seen it where the housing was crack damaged.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-01-2020, 10:15 AM   #4
Benson
Benson's Avatar
[qu
Old 10-01-2020, 11:26 AM   #5
midgetracer
midgetracer's Avatar
If the rubber ball is such a poor fix, how come Ford used in the later models?
midgetracer is offline   Reply With Quote
Old 10-01-2020, 11:52 AM   #6
Benson
Benson's Avatar
Because in the thirties they had real rubber which lasted much longer when soaked in oil.
All I know is that the ones I tried in the 60's turned to mush in short order.
And all of the restoration shops that I worked at refused to install the rubber ball ... too many "comebacks" don't ya know?
Old 10-01-2020, 11:58 AM   #7
BRENT in 10-uh-C
Originally Posted by Benson View Post
Because they had real rubber which lasted much longer.
Yes, there are two major differences. Natural rubber and the durometer of the Ford manufactured ball versus the off-shore based rubber.
BRENT in 10-uh-C
Old 10-01-2020, 12:08 PM   #8
Benson
Benson's Avatar
The offshore people who made the rubber balls in the 60s 70s and 80s were most likely using the same rubber that they later used to make the inner tubes of 10 -15 years ago and some of us know how that turned out!
Old 10-01-2020, 02:06 PM   #9
1930-Pickup
Why does no one make a polyurethane ball with an engineered durometer?
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 10-01-2020, 04:45 PM   #10
mhsprecher
mhsprecher's Avatar
Brent's tip is a very valuable bit of information!
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
mhsprecher is offline   Reply With Quote
Old 10-01-2020, 06:38 PM   #11
Steve Rinaldo
I forgot to mention that my setup does not have a rubber ball and it does have the springs. Steve
Old 10-03-2020, 05:43 AM   #12
Jacksonlll
Jacksonlll's Avatar
Her is a video I did with a camer under the car. It's rough, but it shows a little of what goes on under there.
https://www.youtube.com/watch?v=ry29...cz4R0&index=56
