09-13-2023, 02:30 PM | #1 |
Fog Lights wiring
While going through the parts my Dad acquired for his 36 3 window I found a pair of Unity Fog Lamps.
Any ideas on the best way to run the wiring to the dash? I was thinking if just going through the horn bezel but want to make this look as clean as possible. Not sure what was originally done. I also noticed the switch has 3 posts, Batt, Tail and Road. Am I correct that Batt is run to Neg, Road is run to the lamps? Is Tail used at all? Thanks in advance. |
09-13-2023, 04:18 PM | #2 |
Re: Fog Lights wiring
Not sure if you ca read these…if not I can scan them and get them to you tomorrow.
09-13-2023, 05:54 PM | #3 |
This is awesome. Thanks!
09-13-2023, 06:17 PM | #4 | |
09-13-2023, 09:30 PM | #5 |
You’re welcome!
Instructions came with my ‘38 fog lights.. |
09-14-2023, 07:46 AM | #6 | |
You'd asked what was originally done? Originally nothing was done as driving lamps were not offered by Ford in '36.
09-15-2023, 09:04 AM | #7 |
i would wire them with a relay
