07-12-2016, 09:37 PM | #1 |
model b rod clearance specs
Just curious of what the clearance of rod to crank is?
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ |
07-12-2016, 09:51 PM | #2 |
Re: model b rod clearance specs
same
'31 180A |
07-12-2016, 11:15 PM | #3 |
.001" to .0015"would be good.
When I looked in the Motor's Manual for the rod specs on my 1949 Chevy 216, they said .0005" to .0015", so I set all 6 between .0005" and .00075" and it did fine. |
07-13-2016, 07:14 AM | #4 |
Well it looks like I'm coming in around .003 to .002, i have removed all the shims, so what next? do I have caps ground down to make it tighter?I torqued caps to 30 ft lbs.
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ Last edited by 32forddump; 07-13-2016 at 07:25 AM. |
07-13-2016, 07:23 AM | #5 |
OK, something isn't correct. If the rods have that much clearance, 0.070"-0.080" then the crank has been ground undersize too much or the rods were improperly bored. An original standard 'B' crank rod journal should "mike" 1.875" if memory serves me correctly. Mike the crank journal and rod bore and tell us what you have. With that information, we can give you the proper guidance.
07-13-2016, 07:27 AM | #6 |
07-13-2016, 09:40 AM | #7 |
I read his post as 2-3 thousandths. .002" is OK, I run .002" - .0025" on my race engines. You can take off a half thou easily by rubbing the cap on any flat surface, really flat. Use valve grinding compound if the surface is smooth, or none if using you garage floor.
07-13-2016, 11:40 AM | #8 |
Sorry I was looking at the metric scale first.
07-13-2016, 12:03 PM | #9 |
The Model B rod as Jim said should be set with a clearance of .001-80 to .002-30.
Anything under that you take a chance on smearing the Babbitt, and anything over that is wasted clearance. 216 Chevy rods should be set at .002-3 to .002-80. You can't go by the high or lows of the Babbitt bearing spec. books. Herm. |
