Old 03-17-2022, 12:44 PM   #1
Alan O'Connell
Default 1940 Ford convertible
Did all 1940 Ford convertbles come with power tops or did some come with manual tops?
Alan O'Connell is offline   Reply With Quote
Old 03-17-2022, 03:01 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 1940 Ford convertible
I do believe all 1940 Ford convertibles came stock with power activated tops.
Old 03-17-2022, 05:41 PM   #3
Kube
Kube's Avatar
Jim (19Fordy) is 100% correct.
Kube is online now   Reply With Quote
Old 03-17-2022, 05:48 PM   #4
Alan O'Connell
That's interesting. I just looked at one today that was a manual top. I also checked the H.A.M.B. and the posters say there were some that were manual tops and some that were vacuum operated tops. Now I'm totally confused.
Old 03-17-2022, 05:55 PM   #5
Kube
Kube's Avatar
Do not be confused. There were only vacuum operated 1940 Ford convertibles coming off the assembly line.
Old 03-17-2022, 06:11 PM   #6
deuce_roadster
deuce_roadster's Avatar
This reminds me of the people who insist there was a 32 "heavy" front axle because of hear-say info and a typo in a chart that was published in a street rod magazine. There is a 32 axle and there are 33-36 axles that were used as service replacements.
When the tired engine didn't produce enough vacuum to raise and lower the top, people jerked the cylinders and hoses out.
Old 03-18-2022, 07:35 AM   #7
fortyonerag
fortyonerag's Avatar
If you disconnect the vacuum actuators, it is a very easy top to work manually. This may be the cause of the confusion among some folks
fortyonerag is offline   Reply With Quote
Old 03-19-2022, 02:20 PM   #8
flatmotor40
flatmotor40's Avatar
I use mine manually even though I still have the cylinders and vacumn switch.None is mounted laying on shelf.No problem raise and lower but it would help with 2 people raising it up but 1 can do it fairly easy
flatmotor40 is offline   Reply With Quote
Old 03-19-2022, 07:37 PM   #9
Alan O'Connell
If I do decide to buy a 40 Ford convertible, I would like the top to work like from the factory. I think everything should be completely original. How difficult is it to get parts to repair the top mechanism?
Old 08-20-2023, 05:06 AM   #10
Convert
I am looking for cylinders to replace the ones on my parent’s 1940 Ford. I am a new member and have to make 5 more post (for a total of 9) before being allowed to respond sellers with a private message.
Convert is offline   Reply With Quote
Old 08-20-2023, 03:51 PM   #11
paul2748
paul2748's Avatar
I don't know if they have anything for the vacuum operated tops but try Hydro-E-lectric in Fla. They deal in conv. top parts and may have something or know where you can find what your looking for.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-20-2023, 11:19 PM   #12
Convert
Thank you Paul2748. I will see what Hydro-E-lectric has.
Old 08-22-2023, 08:58 AM   #13
deuce_roadster
The ones I had were easy to repair and make work. Usually, the inside of the cylinders didn't get full of water and rust up horribly. The car I had; I was the first person out of the family that bought it new to own it. The day I sold it, the top went up and down (not real fast!) with a fresh engine. A good switch might be harder to find then usable cylinders if missing.
Old 08-22-2023, 09:05 AM   #14
Automotive Stud
Automotive Stud's Avatar
I saw a pair of cylinders for sale at Carlisle last year. I almost bought them, but I figured mine still work fine after 82 years so having a spare set is probably not necessary.
Automotive Stud is offline   Reply With Quote
Old 08-22-2023, 03:30 PM   #15
Kube
Kube's Avatar
I threw five nice cylinders away last year. Got tired of putting them on eBay with a no reserve starting bid of $10 each with no bids.
Old 09-14-2023, 08:19 AM   #16
Convert
I hope to return from Carlisle and Hershey this year with some good cylinders and enough other 1940 Ford convertible parts to complete the restoration of my car.
