Old 06-29-2010, 07:11 PM   #1
Bill in Al
Bill in Al's Avatar
Default 8BA or 8RT
I have a '48 F1 and it should have an 8RT engine. The heads are marked 8BA and I don't know if the RT engines were marked as such or not.The dipstick is marked RT. Does anyone know if RT engines were marked 8RT on the heads or not? The truck was restored in the mid-eighties and parked in '98 till I got it a month ago. Having a lot of fun with it!-Bill
Bill in Al is offline   Reply With Quote
Old 06-29-2010, 07:17 PM   #2
Henry/Kokomo
Henry/Kokomo's Avatar
Default Re: 8BA or 8RT
I THINK the heads will have "8BA" on them. I KNOW the intake manifold has "8RT" cast on it. The last block I bought had EAB heads but the manifold had 8RT cast on it and the pan had the large clean out so I'm pretty sure it really was a truck engine. Hope this helps. Good luck.
Henry/Kokomo is offline   Reply With Quote
Old 06-29-2010, 07:24 PM   #3
GreenMonster48
GreenMonster48's Avatar
Mine also says 8BA on the heads but 8RT on pretty much everything else.
GreenMonster48 is offline   Reply With Quote
Old 06-29-2010, 07:25 PM   #4
Bill in Al
Bill in Al's Avatar
Thanks,Henry. It does have the large clean-out and tomorrow I'll look at the intake-Could you tell me where to look as it is a bit dirty!-Bill
Old 06-29-2010, 08:18 PM   #5
jdl
jdl's Avatar
Send a message via ICQ to jdl
All of the 8BA intake manifolds also say 8RT, passenger car and truck. I have seen some trucks with 8BA heads and some with 8RT heads. don't know why? someone will say more.
jdl is offline   Reply With Quote
Old 06-29-2010, 08:32 PM   #6
1952henry
1952henry's Avatar
Truck heads should say 8RT if you want to be a purist. That said, the 8BA (late flathead) showed up in the 1948 Ford trucks, and 1949 in Ford cars. I would have to look in my book to see if the 1948 truck heads were 8RT or not. The water pumps, if original will have 8RT, as well as the pump pulleys. The carb should read 7RT on the bowl.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 06-29-2010, 08:39 PM   #7
uncle max
uncle max's Avatar
I like your signature Owen, it makes me smile...
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 06-29-2010, 09:14 PM   #8
denverslim
denverslim's Avatar
I have a truck with the 8RT heads. But I have often wondered if some of the trucks came with 8BA heads cuz I've seen so many of them. Hard to tell unless someone has a book because so many of the engines were swapped around...slim
denverslim is offline   Reply With Quote
Old 06-29-2010, 09:49 PM   #9
1952henry
1952henry's Avatar
Why, thank you! Glad I made your day. BTW, you have a check on the way.
Which one??
Old 06-29-2010, 09:57 PM   #10
ford1
truck should have 8rt on the heads, most of the 8RT heads were replaced as the years went by with the 8BA heads because the 8RT heads were lower compression, every body wanted higher compression heads
ford1 is offline   Reply With Quote
Old 06-29-2010, 10:01 PM   #11
1952henry
1952henry's Avatar
As happens from time to time, I st@2b corrected! My 48-52 Ford truck chassis book, printed January 1952 states the 48-51 8 cylinder engines had head part number 8BA 6049 and 52 8 cylinder engines had head part number 8RT 6050.
I know the correct carbs had the 7RT on the fuel bowls for the F1-F6 trucks and had the rod choke linkage. The 51-52 carbs had 7RT on the bowl but were called the 8RT if equipped with the hand throttle; both hand throttle and choke lever were cable operated.
Old 06-30-2010, 12:16 AM   #12
Karl Wolf
Karl Wolf's Avatar
Do you need an 8rt intake, let me know, Karl
Karl Wolf is offline   Reply With Quote
Old 07-06-2010, 01:38 AM   #13
ken ct
Max,only diff between 7RT has a rod type choke and a 8RT has a cable type choke. ken ct.
ken ct is offline   Reply With Quote
