11-29-2021, 07:41 PM | #1 |
1936 tudour clutch & brake springs, just 2?
My 36 has been down for a while after selling and moving from our last home and last time I adjusted the clutch I either misplaced a spring OR, put the clutch spring in the wrong location so it doesnt have enough tension on it?? Now the clutch is super easy to push which I know isn't correct. Currently there is one spring for the brake pedal and one spring for the clutch pedal but I feel like I am missing one Its hell when you get old is there just two springs total or three???
Thanks! (attached is the only pic I could find but I still feel like there was a 3rd spring?)
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
11-29-2021, 08:10 PM | #2 | |
Re: 1936 tudour clutch & brake springs, just 2?
11-29-2021, 08:57 PM | #3 |
Just the two as you show.
11-30-2021, 07:51 AM | #4 |
Both the clutch and brake pedal return are identical 3.44" 48-7523
11-30-2021, 09:13 AM | #5 |
If it is too easy to push then I'd also be wondering about the pressure plate.
11-30-2021, 05:26 PM | #6 | |
Its understood that the end of clutch spring connects to the end of the adjustable fork on the engine side but if I remember correctly I just have the other end connected to what looks like a bracket, does that sound correct thanks again!
