Old 08-10-2021, 07:39 PM   #1
my4dv8
Default Door windows again
We have a 28 tudor , no glass came with it, so no pattern . All new regulators , USA made tracks , slide felts , all new from Snyders. made the first pattern and it tilted and jammed on the way down only. Mad a second slightly wider pattern ,same deal , also slightly tilted on way up . OK made a third pattern ,slides nicely with some resistance up and down . As soon and the bottom track is clipped on it goes up sort of OK but down is the issue. The wood pattern is screwed to the track at each end. Corners of patterns are nicely rounded. ?? Where to from here?
my4dv8 is offline   Reply With Quote
Old 08-10-2021, 07:57 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Door windows again
Are you sure the corners of the lower track are not binding on the felt runs? Or screws exposed someway??
Contrary, it would seem to be worse up than down.
Oldbluoval is offline   Reply With Quote
Old 08-10-2021, 10:30 PM   #3
my4dv8
Nothin protruding . Tried 3 different size pattens and all slid without the regulator. What I found was in our other cars all with replacement glass the numbers went from 6.2 mm to 5.5 to 4.7mm ( sorry about using metric) No idea but got the air DA out and sanded approx .5 making it 4.7 mm off the flat edge of the pattern and it seems to work much better.
Old 08-11-2021, 05:43 AM   #4
Oldbluoval
Oldbluoval's Avatar
In USA side window uses 1/4” except cabby where 3/16 works better. Your mm is well under that. Any chance you have unacceptable felt channel? I’d take it out and see if binds on template without being installed.
Or without regulator does it move smoothly in door?
