Old 05-21-2021, 02:11 PM   #1
Krylon32
Default 40 Standard Grille Repair
I have a friend with a good 40 standard grille with a bar broken loose at the bottom. You can't see it unless it's pointed out. Is there someone out there that can do a repair on the grille so it wouldn't show? It will be painted.
Krylon32 is offline   Reply With Quote
Old 05-21-2021, 02:17 PM   #2
J Franklin
J Franklin's Avatar
Default Re: $0 Grille Repair
JB Weld might do a fair job.
Old 05-21-2021, 02:21 PM   #3
Krylon32
Default Re: 40 Standard Grille Repair
Looking for permanent fix. Not much of a JB fan
Old 05-21-2021, 02:22 PM   #4
Tim Ayers
I'd assume someone who is a good TIG welder or braze it from the backside.
Old 05-21-2021, 03:55 PM   #5
OldGold360
Where is your friend located?
OldGold360 is offline   Reply With Quote
Old 05-22-2021, 06:47 AM   #6
Terry,OH
Terry,OH's Avatar
The problem with welding the pot metal or white metal grills can be heat which can easily warp the grill and cause blow outs which can be very difficult to try and refill. There are some very good and strong epoxy type adhesives.
Old 05-22-2021, 07:22 AM   #7
TomT/Williamsburg
TomT/Williamsburg's Avatar
Hey, Gary - if you can make a small piece of metal to hold the bar in place, there are some really great glues, JB Weld being be of them, that can do the trick. If it’s a chromed grille, you might have to be a little more creative coloring wise for the little support piece. And I would make the support piece tie into the chin pan. Yes, you know it’s there but from 5’ away you can’t even see it, chrome or painted grille.
I have posted some pics here on the Barn side in a thread about a year or so ago. I will post a couple pics soon as I find them .....
TomT/Williamsburg is offline   Reply With Quote
Old 05-22-2021, 08:08 AM   #8
51 MERC-CT
51 MERC-CT's Avatar
I have and use 'MUGGY WELD' (super alloy 1) to fix pot metal cracks, pits, etc. for parts to be re-chromed.
No high temperature welding necessary. It's just a matter of learning the process and proper preparation.
WATCH THE VIDEO --------------
https://www.muggyweld.com/?gclid=Cj0...IaAjWHEALw_wcB
Old 05-22-2021, 05:41 PM   #9
Tim Ayers
I am no expert, but I thought standard grilles we’re stamped steel. Is this not correct?
Old 05-22-2021, 06:07 PM   #10
42merc
42merc's Avatar
Real '40 Ford standard grilles are die cast.
Once upon a time the aftermarket produced a stamped steel grille.
42merc is offline   Reply With Quote
Old 05-22-2021, 06:46 PM   #11
Tim Ayers
Got it. I've must have only seen repos. Now I understand the question about the repair. Thanks, 42merc.
