10-30-2018, 05:55 AM | #1 |
Sheet metal repair panels
Anyone make sheet metal patch panels for the '37-41 Ford pickup cab back lower corner and bottom of door ? Thank you Fordbaners.
10-30-2018, 06:32 AM | #2 |
Re: Sheet metal repair panels
Isn´t -37 like 35-36 and a -40 same as up to 47...when it comes to cabs...
Howells used to have them listed... |
10-30-2018, 07:01 AM | #3 |
I purchased lower door patch panels (inner and outer) and lower rear cab patch panel from Mac's a few years ago. Fit pretty well. Got bed sheet metal from Mack Hils - top notch.
10-30-2018, 07:58 AM | #4 |
Joe's Antique Auto in Mass has a listing for 1935-1937 pickup
also 1940-1947 1-800 508-3980 They are great people to work with, fair and know the products |
10-30-2018, 08:11 PM | #5 |
So it sounds like 35-37 p/up cabs are the same. How about '38-39 ? And '40-47 are the same ? Does Joe's have '35-37 cab lower rear corner patch panels ? How about Mack Hils. I know they make great p/up bed sheet metal.
10-30-2018, 09:03 PM | #6 |
10-31-2018, 04:50 AM | #7 |
38-39 cabs are different.
I´m not sure if the lower part sheetmetal fitts between the years. I have 35-36 cabs and 42-47 in the yard...no 38-41 at the moment..so cant check it. |
11-02-2018, 06:50 AM | #8 |
I bought both driver and passenger side 38/9 pickup lower door patch panels a few years ago for a project and did not use the passenger side patch panels. If the passenger side would help you either send me a message on Fordbarn or email me at [email protected]. If you email me, please put something in the subject line. I also found a pair of 35-37 pickup replacement rockers that I ended up not using, but I do not know if they would work on a 39 and have no way of checking. O&T
11-11-2018, 03:45 PM | #9 |
the producer of these panels retired in jan. 2017, and the biz closed
11-12-2018, 07:22 AM | #10 |
The spare pair of 35-37 rockers I had hanging around is gone. I still have a set of the lower door repair panels for a 38/9 pickup/truck/panel but for the passenger side only. It seems to me from looking at the outer panel that the door skins would not interchange between 35/7 and 38/8 pickups due to a difference in the height of the lower hinge from the bottom of the door. Someone with one of each to check the measurements would be more help.
11-12-2018, 09:56 AM | #11 |
There is a source (Kansas) for good 1935-37 rocker panels still in business.
The good 1935-37 cowl, door, and cab corner patches are gone. The good 1938-47 cowl, door, cab corner, and floor panels are gone. "Basic" 1938-47 door inner and outer patches are available (Texas) not good, but can be a better value than flat sheetmetal. The 1948-52 tall cab corner patch (not Carpenters) can provide a good base for the 1938-47, but will require the back notch to be hammered in and other moderate reworking. Again, not a great solution but a good value vs flat sheetmetal. |
