Old 12-30-2017, 11:57 AM   #1
40cpe
40cpe's Avatar
Default '38 roll-back window mechanism
The door window in my '38 had gotten really hard to roll up past the point that it slides forward. I took the door panel off and see that this post roller runs in a slot in the regulator. It was gummed up and hard to turn (weather cold). I took it apart and cleaned the old grease out and it turns freely. Question: Should there be any lubricant at all in the roller? If so, what kind? I thought of graphite since it is dry and shouldn't harden.
40cpe is offline   Reply With Quote
Old 12-30-2017, 12:14 PM   #2
Clem Clement
Clem Clement's Avatar
Default Re: '38 roll-back window mechanism
How about some "Red and Tacky" on the gears?
Clem Clement is offline   Reply With Quote
Old 12-30-2017, 12:50 PM   #3
40cpe
40cpe's Avatar
A second part of the question: In this door, the rear glass edge pushes against the steel inner structure of the door for the last inch or so of rise. You can see in this picture where it hits the metal. Should there be a cushion, channel, etc for the glass to slide on?
Old 12-30-2017, 02:13 PM   #4
rich b
rich b's Avatar
I use white grease on the rollers along with the slotted tracks on the lower window channel.
Looks like you are missing the glass run channel on back of that door. What does the other door have there?
rich b is online now   Reply With Quote
Old 12-30-2017, 03:32 PM   #5
fordv8j
fordv8j's Avatar
I also used white grease on all the window mechanism on our 38 convertible, got some in a cup, and some in a spray can for hard to reach places
fordv8j is offline   Reply With Quote
Old 12-30-2017, 03:54 PM   #6
40cpe
40cpe's Avatar
Not sure about the properties of white grease, does it harden and gum up with age and cold weather?
The other door is like this one. I put kits in the doors and there was only whiskers for the garnish and opening on the door. The only channels were for the door below the window line.
Old 12-30-2017, 07:21 PM   #7
4dFord/SC
4dFord/SC's Avatar
I'd use Wynn's Viscotene.
4dFord/SC is offline   Reply With Quote
Old 12-31-2017, 12:11 AM   #8
rich b
rich b's Avatar
I guess I thought the channels went all the way to the top like they do on the earlier cars I am used to. Any chance the glass itself is a little too far back in the bottom channel? I know that make a difference in operation of the vent function, etc.
Old 12-31-2017, 09:20 AM   #9
40cpe
40cpe's Avatar
The glass has 1937 date bugs on it and is slightly delaminating around the top, so I suspect it has been in the car forever. I didn't have any of the suggested lubes for the roller, so I used graphite. I lubed the riser slides and put it together and it is working fine. If it gets dry again I'll try something else.
Thanks for all the suggestions.
