Old 05-09-2015, 01:56 PM   #1
ems customer service
Default sheetmetal videos's repair panels
the newest video's about sheetmetal repair panels
there will be more about floors firewalls coming later
tell use what you think
1935-36 ford
https://www.youtube.com/watch?v=f_K_eKTa0oQ
1937-40 ford
https://www.youtube.com/watch?v=M6mo5hlC0Xk
1941-48 ford
https://www.youtube.com/watch?v=3QndH6sXW6Q
1949-51 ford
https://www.youtube.com/watch?v=ZO4uXwYIWTo
ems customer service is offline   Reply With Quote
Old 05-09-2015, 08:19 PM   #2
corvette8n
corvette8n's Avatar
Default Re: sheetmetal videos's repair panels
Great information thanks
Old 05-09-2015, 09:30 PM   #3
swedishsteel
I've used the rocker panel patch, lower fender patch, cowl patch and all needed to be reworked to match the original sheet metal: the rocker panel is straight and that part of the body is curved--very difficult to match the quarter panel; the same for the cowl patch being straight while the original body is curved; the lower fender panel had to be sectioned both on the outer part and where it meets the running board. Also, the body line of the cowl patch, quarter panel and lower door panel do not match the original, so unless you use all three on the same car, where the original and patch meet needs to be worked so they blend together. I appreciate that EMS is making these panels, but I don't think it would take a whole lot to go from "sorta fit" to "it fits with no reworking". Rod
swedishsteel is offline   Reply With Quote
Old 05-09-2015, 09:41 PM   #4
JSeery
JSeery's Avatar
All the sheet metal panels I've used need rework!
Old 05-11-2015, 09:37 AM   #5
Bolts
Bolts's Avatar
Thanks for posting the videos. It's helpful to see the actual parts. Catalog pictures often don't show the features you want to see.
Nothing wrong with it except for the name on the front.
Alex
Bolts is offline   Reply With Quote
Old 05-11-2015, 10:40 AM   #6
Bulligen
Bulligen's Avatar
We are lucky someone is helping us with these panels, It would be nice if they fit a little bit better, but we should all expect some fitting going on with anything! It is nice to order out of a catalog rather than spending months crawling around in junk yards like we did years ago!
Bulligen is offline   Reply With Quote
Old 05-11-2015, 10:43 AM   #7
waterboychuck
waterboychuck's Avatar
I replaced the firewall, rocker panels on both side and a front floor pan. All fit nicely. My only problem was that there were no instructions that came with it.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 05-14-2017, 04:04 PM   #8
updated video may 2017
https://www.youtube.com/watch?v=D2igixTd_8I
