Old 10-03-2010, 08:18 PM   #21
Da Tinman
Da Tinman's Avatar
Default Re: Electronic Distributor ?
Originally Posted by flathead4dr View Post
I have a late flathead in my 34 ford, and in 8 years and 17,000 plus miles I have never had a whimper of a problem with the stock points distributor. Just last week I decided to check the timing and vacuum advance,( there is no centrifugul advance in these) just to be sure......It's all as originally set. This "load a matic distributor works great with dual 94 carbs. Bill
Have you driven a flatty with the sbc conversion dizzy? You should try it before you knock it.
Da Tinman is offline   Reply With Quote
Old 10-03-2010, 11:38 PM   #22
1oldtimer
1oldtimer's Avatar
look at bubbas posts and page:
http://www.fordbarn.com/forum/showthread.php?t=11050
http://www.lindertech.com/bhrs/flath..._elec_conv.htm
i'm going to send mine over.
1oldtimer is offline   Reply With Quote
Old 10-04-2010, 06:12 AM   #23
345 DeSoto
345 DeSoto's Avatar
Location: Skaneateles,NY(summer)/Port St.Lucie,FL(winter
I've been running a 6V Pertronix unit in my 55 DeSoto with a generator, for five years or so. No problems at all...
..."If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit"...
345 DeSoto is offline   Reply With Quote
Old 10-04-2010, 07:02 AM   #24
Cecil/WV
Cecil/WV's Avatar
Originally Posted by Chris Nelson View Post
If you are going to use an electronic ignition, be sure to use an alternator and not a generator.
I have run my Pertronix for 13000 miles with a generator with no problems.
Cecil/WV is offline   Reply With Quote
