Old 02-04-2015, 12:20 PM   #1
mj40's
mj40's's Avatar
Default Where to find window regulators
I'm looking for a pair of window regulators for a 38 to 47 Ford pickup. would like NOS or nice originals. Anybody?
mj40's is offline   Reply With Quote
Old 02-04-2015, 01:01 PM   #2
trainguy
trainguy's Avatar
Default Re: Where to find window regulators
They show up on That online auction site from time to time.Phil
trainguy is offline   Reply With Quote
Old 02-04-2015, 01:13 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
Have a picture of what they look like? I have a couple of old Army footlockers full of NOS regulators and I just might have what you need.
Ken/Alabama is offline   Reply With Quote
Old 02-04-2015, 01:21 PM   #4
Mike B
Mine are out of the doors right now, will get a pic in a bit.
Mike B is offline   Reply With Quote
Old 02-04-2015, 03:37 PM   #5
G.M.
There's a guy near Mulica Hill NJ that has all kinds of window regulators. I know him but haven't seen him in years. I bought about 12 Columbia rears off him 2o years ago. He go's by Regulator Ted or Jim or what ever his name is. Someone on here should know him. G.M.
www.fordcollector.com
Old 02-04-2015, 04:33 PM   #6
TJ
TJ's Avatar
Regulator Roy, he advertises in the V-8 Times
Old 02-04-2015, 05:03 PM   #7
thirt4
thirt4's Avatar
I am working with "Regulator Roy" at this time on window stuff. I would recommend him.
thirt4 is offline   Reply With Quote
Old 02-04-2015, 05:09 PM   #8
325w
What's wrong with those? Soak them in vinegar for a few days. Grease them up. The springs look to be ok.
Ooopps
325w is offline   Reply With Quote
Old 02-04-2015, 05:19 PM   #9
JSeery
JSeery's Avatar
Those belong to someone else (Mike), I'm sure mj40 would love to have them!
Old 02-04-2015, 08:36 PM   #10
Barry-ct
Barry-ct's Avatar
I looked up the part numbers in my parts book and my book shows from 44-47 to be as following:
01C 8123200-A r/s Dennis Carpenter restorations 1-800-476-9653 Qty 4 in stock
01C 8132301-A l/s same place as above Qty 1 in stock.
I can only verify back to 44, as I don't have an earlier copy back to 38. Maybe someone else can look it up on the earlier truck and verify they are the same.
Dennis Carpenter has a separate division that deals in just NOS stuff.
Hope this helps.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 02-05-2015, 02:13 AM   #11
KendraFowles
I bought my 1936 Cabriolet regulators from Regulator Roy - excellent. http://www.regulatorroy.net/
KendraFowles is offline   Reply With Quote
Old 02-05-2015, 04:38 PM   #12
Ken/Alabama
I found 4 NOS ones in my stuff. Problem is they are all for the same side.
Old 02-05-2015, 05:07 PM   #13
supereal
supereal's Avatar
Consider restoring them if they are complete. We hot tank them to get the rust and crud off, then disassemble them. Missing or damaged teeth are restored by welding them, then reshaping with a die grinder. Many vendors stock a kit for the crank gear and shaft. I used this approach over 20 years ago when I bought my '47 convertible. The open car regulators are very different than the closed car type, and it took me a year to find one for the right door. Someone had put a regulator from some kind of car in that side When I did find one, it was very expensive, and still needed to be rebuilt.
supereal is offline   Reply With Quote
Old 02-05-2015, 11:22 PM   #14
mj40's
mj40's's Avatar
I found a NOS passenger side on ebay. It looks like yours are missing a rivet on the strap the keeps the two gears in place at the center. One end is bolted and the other end riveted.
Even duct tape can't fix stupid ... but it can muffle the sound!
Old 02-06-2015, 07:34 AM   #15
Dec211975
I tried to rebuild some a couple of years ago that appeared to be in pretty good shape the window crank gear and shaft were bad. The kits that I got to repair these were not the same tooth count. I was told nobody ever had this problem before. I don't know if the 38 to 47 truck (Pickup) takes a different kit or if the ones I recieved were packaged wrong.
Dec211975 is offline   Reply With Quote
