Old 04-21-2013, 06:17 PM   #1
supergnat
supergnat's Avatar
Default Distilled water dispenser??
A friend from church is cleaning out her late brother's house and found an item that someone told her was a distilled water dispenser for Model T or A era cars. It is a metal frame with a gallon jug. Does anyone recognize this item and if so what should I tell it is worth. Any guidance would be appreciated.
Thanks,
Supergnat
supergnat is offline   Reply With Quote
Old 04-21-2013, 06:31 PM   #2
Mendotaman
Mendotaman's Avatar
Default Re: Distilled water dispenser??
Sent private message
mm
Mendotaman is offline   Reply With Quote
Old 04-21-2013, 10:29 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Maybe for batteries?
Old 04-22-2013, 10:52 AM   #4
tmiller6
tmiller6's Avatar
I can't see the end with the cap in your photo. I have one and was told it was for oil lamp fonts. Mine has a spring loaded lever sticking out of the cap. I would think this mechanism would have rusted away if water had been in the bottle.
tmiller6 is offline   Reply With Quote
Old 04-23-2013, 06:05 AM   #5
supergnat
supergnat's Avatar
Thanks for all the replies. I gave the item back to the owner so she can let the antique dealer sell it for her. I doubt anyone in our club would buy it. One sold on Ebay recently but it had markings to identify its use. Perhaps these dispensers had multiple uses.
Supergnat
Old 04-23-2013, 09:50 AM   #6
Special Coupe Frank
Special Coupe Frank's Avatar
The gallon-sized glass jars with the springloaded plunger in the metal cap are usually from Kersone or "oil" cook-stoves.... Lehman's Hardware in Kidron Ohio still sells them.
Special Coupe Frank is offline   Reply With Quote
Old 04-27-2013, 01:01 AM   #7
KR500
KR500's Avatar
It is absolutely for refilling batteries. There is a small ring on the side to clamp the fill tube up so it does not leak and also a hook to hold a hydrometer.
KR500 is offline   Reply With Quote
