12-03-2011, 05:40 PM | #1 |
What cover for this heater?,unknown mfr.
I have a heater in my '41 without a cover.The blades (4)are 8" long. The core is round,circular,and 9" across.The blades are in front of the core, facing the seat.There is a 3/4"frame around the cores' back edge. On each side of the frame there are two screws about 2" apart that look to hold a cover in place. I can't find any identifying name. Does anyone recognize what make it is so I'll know what to look for? Bill
12-03-2011, 08:48 PM | #2 |
Re: What cover for this heater?,unknown mfr.
Chevrolet used a round core for some of their heaters.
12-03-2011, 10:57 PM | #3 |
Do you have any pics?
When will I be old enough to know better? |
12-04-2011, 02:18 PM | #4 |
Heh,Heh! 41fords ohio,I'm old enough to know better, but too old to know how to post pix!!-Bill
12-04-2011, 06:06 PM | #5 |
Bill, I'd really be interested in seeing your heater core. If you'd like to post a picture here are the simple steps:
1. Under the box where you write your post click the "Go Advanced" box. 2. Click the paper clip above the message writing area. 3. Click on the first "browse" box at the top. 4. Navigate to your picture. Make sure it's not more than 800 pixels wide. (If it's more that's another few steps to reduce the size.) Double click on it. 4. Click "Upload." Check to be sure the photo shows up under "Upload." 5. Click "Close this Window" at the bottom (or just the X in the top right corner of that window." You're done. Finish your message and post it and the picture will be under it.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
12-04-2011, 11:15 PM | #6 |
12-05-2011, 08:24 AM | #7 |
That's an arvin aftermarket heater. They were dealer installed in some cases. My 46 coupe has one too.
Matt
"..Nothin' outrun my V8 Ford" (Chuck Berry) S.M.I.B. |
12-05-2011, 08:32 AM | #8 |
You're right,it is a Arvin, 4 out of 7 of the 41s I've owned had one. It seems to have been the most common in the area I lived in( Ohio) Go figure,don't know why. Ed
12-05-2011, 01:13 PM | #9 |
Banned
Reason could have been because they were built close by (I don't know) but probably because they worked well. Back then dealers not only wanted to make a sale, but to satisfy customers also. Not like todays high pressure sale- forget about you dealers.
12-05-2011, 09:44 PM | #10 |
It's not an Arvin like the one pictured.It is mounted verticaly with the fan facing the seat. It doesn't work all that good either, so I guess I'll go ebaying! (thanks Old Henry for the instructions)Thanks all! Bill
12-06-2011, 06:50 AM | #11 |
Banned
Could it possibly be that it doesn't work good because the whole case isn't on it? Or possibly a partial core plugup because of the years on it?
