Old 05-22-2017, 11:26 AM   #1
supergnat
supergnat's Avatar
Default Fordor gas tank felt sealer
I am ready to install my replacement gas tank of my 28 Fordor Leatherback. The original 6" X 6" felt was salvagable after removing the hardened tar-like sealer arounf the hole for the tank filler spout. What sealer should I use on the felt before I install the tank?
Thanks,
Supergnat
supergnat is offline   Reply With Quote
Old 05-22-2017, 12:21 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Fordor gas tank felt sealer
None is really needed as that is just an anti-squeak however anything from trim adhesive to duct tape will suffice while you are installing the tank.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-22-2017, 01:07 PM   #3
supergnat
supergnat's Avatar
Thanks for the tip Brent. Here is a better photo of the felt as it appeared on my original tank. I will use Permates #2. I thought the original material on the felt was there to prevent spilled gas from seeping under to cowl. It was hard and brittle so I was able to crush it and salvage the felt.
Supergnat
Old 05-22-2017, 01:08 PM   #4
J Franklin
J Franklin's Avatar
The black sticky vinyl like flashing material used on window replacement flashing and roof ice dams would serve that purpose.
Old 05-22-2017, 01:50 PM   #5
supergnat
supergnat's Avatar
J,
Great suggestion. That is what I will use.
Thanks
Old 05-22-2017, 02:28 PM   #6
SeaSlugs
SeaSlugs's Avatar
just make sure its gas safe.... Wouldnt want the gas/fumes to start melting it...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-22-2017, 02:46 PM   #7
J Franklin
J Franklin's Avatar
I would think the original was tar and felt and would have also had a problem with any fumes.
