01-08-2015, 08:03 PM | #1 |
8ba engines
Is there a way to identify the 49-53 engines, picked up one the other day,color was tangerine,guy said it was a ;49 ,Vanpelt says blue for 49 ,orange or tangerine for 50 pretty sure it has never been painted before,most of paint is gone,it does have valve seats in the ex anyway,had the assembly out today.stuck ,,,02391 is on rear of motor,,the od transmission had a Little
blue on it.
DON P |
01-08-2015, 08:17 PM | #2 |
Re: 8ba engines
The valves/springs/keepers changed to the rotator type in '51. Check the rear vertical face of the block next to the oil pump drive for a casting number (inside the bellhousing circle).
'52 F-1, EAB flathead |
01-08-2015, 08:25 PM | #3 |
Re: 8ba engines
Well, I'll probably get tromped on but as I understand '49 doesn't have a fuel pump rod bushing and '51-53 have "1BA" embossed on the back of the block inside the lifter galley.
Lonnie |
01-08-2015, 08:34 PM | #4 |
Re: 8ba engines
Never seen a 49 to 53 flathead WITHOUT a fuel pump bushing 49 not having abushing is not correct.
01-08-2015, 08:36 PM | #5 |
Re: 8ba engines
I have build a couple 48 pickup 8BA engines, they didn't have a pushrod bushing, also had 1/8 pipe plug on the back of the block so they could drill a small hole through the pushrod bore into the main oil line to lube the pushrod. Also had heads studs instead of head bolts. Seems there was a couple of other thing on the first 8BA style that Ford was trying out before installing 8BA in the 49 cars and trucks. Walt
01-08-2015, 10:17 PM | #6 |
Re: 8ba engines
01-09-2015, 07:07 AM | #7 |
Re: 8ba engines
Yes, I have seen the small diameter pushrod and no bushing in the early 8BA style blocks.
01-09-2015, 08:42 AM | #8 |
Re: 8ba engines
'49 is blue, 50-51 is Bronze and later are Tangerine/orange. trucks were mostly red.
01-09-2015, 09:22 AM | #9 |
Re: 8ba engines
Whenever I am doubt, I just refer to the chart on this link:
http://flatheaddrag.com/birthday.html Has never failed me yet. |
01-09-2015, 07:40 PM | #10 |
Re: 8ba engines
Great,will check mine in the morning,close to 5* out and dark.
DON P |
01-10-2015, 08:00 AM | #11 |
Re: 8ba engines
Some years of Mercury were green.
