11-27-2020, 10:53 AM | #1 |
fender panel padding
So I put the front clip back together on my 47 coupe, and I noticed that the panels behind the grill had some kind of staples going through them where it mated up against the fender for what i assume is some kind of padding. Is this the same stuff as the fender welting, and how does it attach?
11-28-2020, 12:16 AM | #2 |
Re: fender panel padding
My '41 had welting stapled from the factory. assume it is the same on a '47. I glued mine in place before ass"y
11-28-2020, 12:43 AM | #3 |
I had felt strips on some and rubber kinda stuff on other pieces. I would think some sorta closed cell foam would be a good substitute.
12-02-2020, 03:22 PM | #4 |
is something that needs to be glued into place, or fastened?
12-02-2020, 04:19 PM | #5 |
