Old 11-01-2020, 04:23 AM   #1
30-9
Default 39 LED tail lights
Hi Gents
Stock 6 volt positive ground.
I installed leds in rear tail lights. The type that has 72 bulbs and is a complete unit. I also needed to install inline resistors in order to excite the flasher.
Will the wrong size resistor impact brightness. I also notice the flash is much quicker (on -off) when using turn signal.
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 11-01-2020, 12:08 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 39 LED tail lights
the resistor is to make a load to equal a regular bulb, there are also flashers made to run led bulbs----with a thermal flasher the load determines flash timing
Old 11-01-2020, 12:19 PM   #3
Krylon32
I just did the Technostalga 40 taillight conversion on my 40 standard and didn't add resistors or change the flasher. The front turn signal bulbs provided enough resistance so the new lights function correctly
Krylon32 is offline   Reply With Quote
Old 11-01-2020, 01:35 PM   #4
30-9
Thanks but could it take voltage away from the bulb? My led bulbs are not as bright as I would think LEDs should be.
Thanks - 30-9
1939, 1940
Old 11-01-2020, 02:18 PM   #5
JSeery
JSeery's Avatar
You can try jumping around the resistor and see. If there is a big difference try an electronic flasher.
Old 11-01-2020, 02:31 PM   #6
30-9
Thanks Mr Seery
If I go electronic flasher, since it’s 6 volt pos, anything special I need search other than 6v electronic flasher.
I’m not very good w electric.
Thanks - 30-9
1939, 1940
Old 11-01-2020, 02:38 PM   #7
JSeery
JSeery's Avatar
Originally Posted by 30-9 View Post
Thanks Mr Seery
I really don't know know the 6v flashers, I will have to do some checking.
Know nothing about these units, but sounds like it would work: https://www.amazon.com/Flasher-Negat...0JEDXT664YED4J
Old 11-01-2020, 02:48 PM   #8
30-9
Originally Posted by JSeery View Post
I really don't know on the 6v flashers, I will have to do some checking.
No nothing about these units, but sounds like it would work: https://www.amazon.com/Flasher-Negat...0JEDXT664YED4J
Thanks it but says neg: 6 Volt 3-Prong Electronic LED Turn Signal Flasher Relay, Neg. Ground, ELF33-6
Still ok?
Thanks - 30-9
1939, 1940
Old 11-01-2020, 03:00 PM   #9
JSeery
JSeery's Avatar
Yep, but they are out there:
https://www.ledlight.com/flasher-6-v...e-chassis.aspx
Shipping is a killer on this one, but this is an idea of what is available: https://www.ebay.com/itm/6V-ELECTRON...-/182510465226
Old 11-01-2020, 03:04 PM   #10
30-9
Thank you so much, have a wonderful day!
Thanks - 30-9
1939, 1940
Old 11-02-2020, 11:23 PM   #11
TomO
the signal stat 181 should work without adding the resister
https://www.ebay.com/itm/181-Signal-....c100677.m4598
TomO
TomO is offline   Reply With Quote
Old 11-03-2020, 02:24 PM   #12
JSeery
JSeery's Avatar
I can't find any info on the stat 181 working with LEDs. It may, but you would think they would point it out if it did!
Old 11-03-2020, 05:27 PM   #13
Jack E/NJ
Jack E/NJ's Avatar
>>>Thanks but could it take voltage away from the bulb? My led bulbs are not as bright as I would think LEDs should be.>>>
It shouldn't. One end of the resistor is connected to the hot wire from the flasher to the LED. The other end of the resistor is goes directly to ground. It's called a parallel connection. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
