Old 09-15-2020, 05:08 PM   #21
KGS
KGS's Avatar
Default Re: NGK Plugs
Originally Posted by GB SISSON View Post
Why B4L and not B6L?
GB, B-4L is a hotter plug. Probably a number of reasons to use a hotter plug. I've used them in engines that used oil and they ran better and burned cleaner than with a colder plug. Otherwise, I use B6L.
Ken
KGS is offline   Reply With Quote
Old 09-15-2020, 05:14 PM   #22
Russ/40
Russ/40's Avatar
Best of all the choices for me.
Russ/40 is offline   Reply With Quote
Old 09-15-2020, 05:41 PM   #23
51woodie
51woodie's Avatar
Which NGK would be best in a stock 59AB?
51woodie is offline   Reply With Quote
Old 09-15-2020, 06:28 PM   #24
GB SISSON
GB SISSON's Avatar
I overhauled mine about 3000 miles ago , 120# compression, uses no oil I guess I'll buy the 6!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
GB SISSON is online now   Reply With Quote
Old 09-15-2020, 06:52 PM   #25
Ronnieroadster
Ronnieroadster's Avatar
Stock use the B6L
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 09-15-2020, 07:25 PM   #26
safeguy150
Thanks to everyone for the glowing reviews of the NGK's, I originally got the recomend from someone local and was not sure.
Thanks again everyone
safeguy150 is offline   Reply With Quote
Old 09-15-2020, 07:31 PM   #27
27TV8
27TV8's Avatar
Hello Anyone use an Autolite 386?
I am useing them on a stock 221 with dual exhaust and an old 30s Roof intake with no heat and two 81 carbs runs fine but last weekend we went on a Toy Run and lots of stop and go,started to run rough so I detoured on to the hyway for a couple of miles and it cleared right up? I might just try some B6L
Thanks
27TV8 is offline   Reply With Quote
Old 09-16-2020, 03:00 AM   #28
Graeme / New Zealand
Graeme / New Zealand's Avatar
B6L in mine
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 09-16-2020, 07:13 AM   #29
V8 Bob
V8 Bob's Avatar
The B4Ls run a little cleaner with the cam and straight-linked triple 97s on the 286 in my roadster.
V8 Bob is offline   Reply With Quote
Old 09-16-2020, 12:22 PM   #30
Gezer
Gezer's Avatar
What Gap is used on the B6L NGK plugs?
Do these plugs burn hotter that a 216 Autolight?
Gezer is offline   Reply With Quote
Old 09-16-2020, 01:57 PM   #31
Ronnieroadster
The B6L is equivalent in heat range and operation wise to the 216 and the Champion H-10 The difference in the NGK is they will perform much better compared to the other two. At least thats what I experience when comparing the three in equal / identical applications. For gap .035
Ronnieroadster
Old 09-16-2020, 08:55 PM   #32
GB SISSON
GB SISSON's Avatar
OK, I am always questioning. So for my stock, but 12v 221 I want to set my plug gaps to .035? Hoping to pick them up on Saturday if the smoke clears up enough to find the Napa store.
Old 09-17-2020, 04:41 AM   #33
Mart
Mart's Avatar
Personally I wouldn't use a gap as big as .035. The HT side of the ignition can be a weak point and the spark will try and go anywhere except across that plug gap. It takes a lot more energy to jump a 35 thou gap than a 25 thou gap.
I have always used the autolite 216s. They work ok for me. I will probably try some NGKs next time, but I can't see how they will be better. As long as they work ok they will be as good as the 216s.
You need to have a plug type that is giving problems to then state that the replacements are an improvement.
NGK are a quality brand though and are an OEM supplier to the automotive industry.
Mart.
Old 09-17-2020, 07:56 AM   #34
Automotive Stud
Automotive Stud's Avatar
I've been using the B4L also, helps with a little cam to keep them clean.
Automotive Stud is offline   Reply With Quote
Old 09-17-2020, 10:15 AM   #35
Jockeyshift41
Jockeyshift41's Avatar
Not 100% certain but I was always under assumption that plug gap for points is different from electronic ignition around .010” smaller? .030” points .040” electronic. Depending on the system? And magnetos even smaller? Say .025”? Just asking ��
Al
Jockeyshift41 is offline   Reply With Quote
Old 09-17-2020, 10:28 AM   #36
flatford8
flatford8's Avatar
I switched to H10’s because I had three electrodes pull out of the 216’s. Never thought to use NGK, but I’ll give them a try next time I swap plugs....... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 09-17-2020, 11:20 AM   #37
V8 Bob
V8 Bob's Avatar
I stopped buying 216s many years ago because of poor quality with misplaced center and ground electrodes, made in China.
Old 09-17-2020, 01:46 PM   #38
Ronnieroadster
Mart.
Mart the plug gap at .035 if its a 6 volt system or 12 volt would only be the weak point of the HT side of the ignition circuit if the plug wires being used are junk. Since many of us have had problems with both the 216 and the H-10 stating the NGK replacements are an improvement is exactly what we are doing.
Ronnieroadster
Old 09-17-2020, 09:23 PM   #39
GB SISSON
GB SISSON's Avatar
As for me it was the crappy plug wires. I learned a lesson about path of least resistance, and now I want the best HT side I can conjure up. Best plugs, best gap etc,.
Old 09-19-2020, 01:49 PM   #40
Gezer
Gezer's Avatar
What gap should be used on B6L NGK plugs in a EAB stock Flathead
